sHow to calculate duration of audios? Does it have anything with encoding, type and frame rates?
I am having a problem because When I calculate duration of an audio with external tools, I find a certain value, but when I open it on Premiere Pro, I get another value.
For example, I have an audio clip that has a duration of 2517 ms = 2s + 15.51 frames.
But inside Premire Pro it shows 00:00:00:02:12 = 2 s + 12 frames ~ = 2 s + 12x33.33 ms= 2399 ms
I would like to achieve 99%+ precision.
Another example was correct:
An audio calculated to have 3880 ms = 3s + 880 ms = 00:00:03:26 ~
It has the same inside PPRO.
But the first example was an "accelerated" audio (through a process that I am not sure about yet),
My question:
how can I ensure the length of audios are always the same, can I modify somethign about my files to make them always "compatible" with PPRO? Maybe some encoding or something about frames etc?
I guess I am looking at tools that modify my audios to make them display same lengths weither they are shown inside PPRO or calculared with external tools.
The accelerated Audio showed wrong values, and it's a problem for me.
(Ps. the duration is calcualted on the already accelerated audio, it's not a prediction).
Thanks
