SOLVED | Help! "A low-level exception occurred in: Adobe Player (Player:11)'.
  • December 7, 2019
  • 10969 views
I'm in a desperate situation. I'm having a problem with Premier that is crashing every time I tried to play a sequence and an error appears "A low-level exception occurred in: Adobe Player (Player:11)'.
I converted some of my archival footage because I was told that maybe was the MP4 clips. But even though I converted to MOV the problem still happening...
They also told me to copy everything in a new sequence and nothing 😞
I googled a thousand things and nothing is helping!
Would someone able to help? I would really appreciated
Correct answer carlar44517643
Just for everyone. My PP 2020 had a bug that al the clips with more than 200% speed were making my project crash and give me that error. Chagning the speed at 199 fixed the problem. Hopefully the fix the bug soon.
You said you converted it to .mov, but that doesn't mean much. .mov is a container. Is the file an uncompressed format like ProRes or Animation?
See my reply and explaination to the same issue here: https://community.adobe.com/t5/premiere-pro/help-adobe-premiere-pro-cc-2020-error-a-low-level-exception-occurred-in-adobe-player-player-11/m-p/10767319#M239546
carlar44517643AuthorCorrect answer
I only ever started recieving this error when I changed my GPU over to a newer (GTX 1660ti)
Don't know if that's of any relevance to anyone? 😛
