Sonoma 14.6.1 and Premiere 24.6.1 Red playback problems.
  • September 9, 2024
  • 21 replies
  • 1757 views
After updating to Sonoma 14.6.1 playback of red camera footage is no longer smooth.
There seems to be a frame freeze for a split second at the end of each clip right before transition to the next clip during playback on the timeline.
I have tried resetting all settings in Premiere and restarting the computer but the problem is if anything worse afterwards.
I have tried turning off hardware acceleration from the seetings>media>enable hardware acceleration.
I had no issues before updating the operating system.
Apple M1 MAX Macbook pro with 64GB ram.
It is currently impossible to edit with this issue and I have deadlines to meet.
TehbenAuthor
25.1.0 BETA build 62 is better but still having some playback glitch between edit points.
jamieclarke
Hi @Tehben - Can you try installing Premiere Pro version 25 and let us know if you are still having issues?
Erik Hutch
Forgot to say that my workaround is to create a new project and import the latest sequence from the previous project. Seems to last for a half a day or so before I have to do that again.
Erik Hutch
Apple M1 Ultra - 128GB memory - Sonoma 14.6.1 - Any solutions yet? I've tried everything here. The diagnostics told me to upgrade to Premiere 24.6.3. No change. Is Premiere 25 worth trying, or would it better to roll back? Ventura and Premiere 23 were really stable :o.
I'm having the same issue with files that are 1080@ 59.94, mp4. On an m1 max with 64GB of RAM. On Sonoma 14.6.1 and Premiere 24.6.1. Can't scrub through my file. Too much lag and takes too long to update the program monitor. However, v23.6.9 has no issues with this.
Jessdesign
I'm having issues as well with playback since updating to Sonoma 14.6.1
I got a new (refurbished) Macbook Pro M2 16gb, I don't know what version OS it came with but I edited an entire project without issue on PP.
Prior to this I had the exact same spec Macbook pro M2 from a company and Sonoma 14.3 was on it and it was fine. I edited plenty of projects, same camera, same settings, same template starter file.
On this new sonoma 14.6.1 I opened up the same projects I edited right before the forced update and playback glitches often becoming unusable and I have to close the app and re-open. I'm also having playback issues in Davinci Resolve though I don't have experience with Davincie resolve on any other device or macOS.
jamieclarke
Does this happen on all workspaces or just one?  Can you try going to Workspaces and select reset saved workspace
Can you try holding shift while opening premiere and check the box that says reset media cache.
TehbenAuthor
No change.
jamieclarke
Can you try deleting the audio and see if it still happens.
Do you have any external monitors connected?  Can you unplug them if you do.
TehbenAuthor
No change with audio input set to None.
