Sep 9, 2024 6:34 PM UTC
Sonoma 14.6.1 and Premiere 24.6.1 Red playback problems.
After updating to Sonoma 14.6.1 playback of red camera footage is no longer smooth.
There seems to be a frame freeze for a split second at the end of each clip right before transition to the next clip during playback on the timeline.
I have tried resetting all settings in Premiere and restarting the computer but the problem is if anything worse afterwards.
I have tried turning off hardware acceleration from the seetings>media>enable hardware acceleration.
I had no issues before updating the operating system.
Apple M1 MAX Macbook pro with 64GB ram.
It is currently impossible to edit with this issue and I have deadlines to meet.
jamieclarke
Sep 10, 2024 8:49 PM UTC
Can you check your Settings > Audio Hardware and make sure Default Input is set to "No Input"
TehbenAuthor
Sep 10, 2024 8:36 PM UTC
@jamieclarke Hardware is enabled. I have also tried disabling it.
https://vimeo.com/1008201702/e7e0ffe766?share=copy
jamieclarke
Sep 10, 2024 8:25 PM UTC
Can you check your settings > media and make sure the check box is set to "Enable hardware decoding".
Do you have any panels open, if so can you try closing them.  Can you post a screen recording so that we can see your issue.
TehbenAuthor
Sep 10, 2024 8:21 PM UTC
@jamieclarke Beta has the same issue. Also tried disabling plugins.
TehbenAuthor
Sep 10, 2024 8:13 PM UTC
Weird the Beta version was nut under the Beta tab but I found it follwing your instructions and willl give it a shot.
TehbenAuthor
Sep 10, 2024 8:10 PM UTC
The only plugin I have is Filmconvert Nitrate and disabling it does not fix the problem.
Premiere does not show up under the Beta tab in the adobe cloud app.
jamieclarke
Sep 10, 2024 11:57 AM UTC
Hi @Tehben - what plugins and version are you using?  Can you try going to the "effects" panel and click the hamburger menu, there will be a manage third party effects at the bottom of the menu.  Try disabling there and let us know if that helps.
TehbenAuthor
Sep 9, 2024 11:25 PM UTC
I tried shift launch and turning off plugins for one time and it had no affect.
Sep 9, 2024 8:36 PM UTC
Updating the status of this bug report.
TehbenAuthor
Sep 9, 2024 7:24 PM UTC
UPDATE: I've never needed to in the past but I just realized I can render the timeline to get smooth playback and get around the issue for now.
