Sep 9, 2024 6:34 PM UTC
Sonoma 14.6.1 and Premiere 24.6.1 Red playback problems.
After updating to Sonoma 14.6.1 playback of red camera footage is no longer smooth.
There seems to be a frame freeze for a split second at the end of each clip right before transition to the next clip during playback on the timeline.
I have tried resetting all settings in Premiere and restarting the computer but the problem is if anything worse afterwards.
I have tried turning off hardware acceleration from the seetings>media>enable hardware acceleration.
I had no issues before updating the operating system.
Apple M1 MAX Macbook pro with 64GB ram.
It is currently impossible to edit with this issue and I have deadlines to meet.
jamieclarke
Sep 9, 2024 7:22 PM UTC
Hi @Tehben - Do you have any third party plugins installed?  Can you check and see if you experience the same issue with the beta of Premiere Pro.  You can find it in the all apps tab at the bottom of the page in the creative cloud desktop app.  Thank you.
