질문
sound only in 1 ear after switching from normal preset to vertical preset
  • January 5, 2024
  • 2 답변들
  • 359 조회
im trying to edit videos in a vertical format.
i import my clip, sound works fine. i go to sequence, settings then switch the frame size from default from 1920:1080 to 1080:1920 (to put it in a vertical aspect). then when i put the clip into the editer, only 1 ear is heard. ive tried editing it and adding fill left with right and vise versa, ive tried everything
everytime i try to input the clip on the vertical settings it says CLIP MISMATCH WARNING
what i dont understand is how does chaning the format effect the sound? they are completely unrelated.
how do i fix this? If i cant get help im not going to use adobe premier pro as editing clips in a vertical aspect is ESSENTIAL
    이 주제는 답변이 닫혔습니다.
    2 답변
    Peru Bob
    Delete the Media Cache and Media Cache files:
    https://community.adobe.com/t5/premiere-pro/faq-how-to-clear-your-media-cache-in-30-seconds-in-premiere-pro-2020/m-p/11017257/thread-id/260446?page=1
    If that doesn't work, try resetting the preferences:
    https://community.adobe.com/t5/premiere-pro/faq-how-to-reset-trash-preferences-in-premiere-pro/td-p/8236158?page=1
    Reset a workspace
    1. Do one of the following:
    • Click the Workspace menu icon and select Reset to Saved Layout.
    • Choose Window > Workspace > Reset to Saved Layout.
    from here:
    If that doesn't work, try Preferences > Audio Hardware and set Input to None.
    If that doesn’t work, try updating or rolling back your graphics driver directly from the video card manufacturer’s site. If NVIDIA, do a clean installation of the latest Studio Driver (NOT the Game Driver).
    If that doesn't work, try creating a new project and import the old one into it.
    John T Smith
    You need to ask program questions in the forum for the program you are using
    To ask in the forum for your program please start at https://community.adobe.com/
    Moving from Using the Community (which is about the forums) to the correct forum
