Speed/Duration Playback Issue in Premiere Pro 2020
  • November 6, 2019
  • 24 replies
  • 10077 views
When remapping speed using the speed/duration function, it is unable to playback correctly in the timeline.
However, the clips still export correctly. The problem is simply with playback after speed is changed. I've tested across different machines and projects, and the problem is across the board.
Please fix!
Brandon
Correct answer Ann Bens
What if you render the clip first?
I'm so tired of this issue. going to revert back to a previoud version of Adobe to resolve it. my work flow is getting intrupted with this.
Seth Pleasants
When will this be fixed? I was sure it would be in the latest update but it isn't.
I posted this thread 7 months ago, and there's still no fix. Insane.
Seth Pleasants
Yeah, how many projects in today's videos use speed ramping? Seems like this should be a huge priority and STILL just updated today doesn't work.
Try this: just go to Edit>Preferences>Audio Hardware and change the default input from Digital Audio S/PDIF High definition audio device and change it to none. And look at the results. It's weird but gonna work 🙂
Seth Pleasants
That didn't work for me ) :
Are they going to fix this? What the heck!
creophoto
I'm also having this issue on my team. We remap for home listing videos, and no matter how I try to view the clip, by scrubbing, using the arrow keys, etc. the remaped clip just spazzes out. Then it looks fine in the export.
The only workaround our team has found is to nest the clip first, then remap it.
Peter A Lund
Has somebody tested it in combination with After Effects? At least you can see the speedramps there and then integrate the clip with copy and paste back to premiere.
I will check it myself but I stopped using speedramps. So I will go into some material and Check it.
rejoice in the way things are.When you realize there is nothing lacking,the whole world belongs to you.>Be content with what you have;rejoice in the way things are.When you realize there is nothing lacking,the whole world belongs to you.
Seth Pleasants
Same issue, please fix ASAP Adobe!
I had export problems as well that I haven't troubleshot just yet, but turning off hard ware acceleration looks like it may have solvedbitbfor me. I also dropper playback res like mad, but it is better than guessing at what frame you are actually working with.
create a new workspace or simple use a default one (editing, color etc) and give it a try.
Jazzman13
same here
I found a solution. I disabled Hardware Acceleration decoding from preferences, restarted Premiere and it works.Of course you loose cpu acceleration but you can work, until a fix in a future release.
BEFRS
Doesn't seem to work on my iMac. Guess I'll have to switch back to CC2019 for now.
Thanks for the tip, anyway!
Sorry to hear that. I am on a windows 10 pc, i7 8700k. I am working with 2019 as well, for now!
