Speed/Duration Playback Issue in Premiere Pro 2020
When remapping speed using the speed/duration function, it is unable to playback correctly in the timeline.
However, the clips still export correctly. The problem is simply with playback after speed is changed. I've tested across different machines and projects, and the problem is across the board.
Please fix!
Brandon
