Speed/Duration Playback Issue in Premiere Pro 2020
  • November 6, 2019
  • 24 replies
  • 10077 views
When remapping speed using the speed/duration function, it is unable to playback correctly in the timeline.
However, the clips still export correctly. The problem is simply with playback after speed is changed. I've tested across different machines and projects, and the problem is across the board.
Please fix!
Brandon
Correct answer Ann Bens
What if you render the clip first?
Same issue, any sort of speed ramp or speeding up doesn't play back.
Imported the files into 2019 version and it all worked fine.
I'l having the same issue wuth speed duation function too.
same here!
Setting I/O points and rendering the clip does allow for normal playback, yes.
However, I see this as a temporary solution, as we should be able to play back time remaps without rendering and storing excessive video previews. Hopefully Adobe addresses in an update soon.
But still thank you!
Joe Hirst
Still an issue to this day. Rendering in some instances does not fix the issue. [text deleted by mod: keep it civil]
