Unable to hear audio passed audio channel 3 and all audio is coming out in mono
  • December 29, 2023
  • 11 replies
  • 2108 views
Hi there, I am having an issue where all of my audio is coming through as mono on my timeline, even though I have recorded in stereo. Also, on my timeline, sound does not work passed audio channel 3. Anything on audio channel 1&2 are fine but below this, it does not work, do you know how to fix this
Stan Jones
Re the screenshot of Audio Channels, this shows that you only have audio on channel 1 and 2. So regarding the title of your thread, you wouldn't get audio from this clip for more than 2 channels.
Stan Jones
What do you get when you drag the clip to that sequence?
so are all these settings correct ?
You cannot reset the audio.
Have to start an new sequence and copy content over.
Thank you so much. Where do I find both of these things to reset ?
Best is to start over and set the sequence audio channel format to stereo.
Also the field option should be Progressieve (unless you are shooting interlaced but I doubt that.
 here we go
Stan Jones
Excellent; thanks.
The screenshot I would also want is clip in Project Panel, right-click -> Modify ->Audio Channels.
Stan
Here is my UI, with my sequence settings, audio and audio hardwrae settings
