scotty321
Oct 10, 2015 2:24 PM UTC
Video and audio tracks unlinking on their own?
Has anybody experienced this very bizarre problem with Premiere Pro CC 2015.0.2? (I'm using Mac OS X 10.10.5.)
Several times per day while working with Premiere Pro, the "linked selection" option randomly stops working. The only solution that I have found for this is to completely quit & relaunch Premiere Pro... but then the problem comes back a little while later.
The problem is this: Even though the "Linked Selection" option is selected for my timeline, if I click on a video clip, the linked audio clip DOES NOT automatically select with it! If I click on an audio clip, the linked video clip DOES NOT automatically select with it! Even if I hold down the option key, the video & audio clips will not select together. This happens for ALL THE CLIPS IN THE ENTIRE SEQUENCE! I am forced to quit & relaunch Premiere Pro, and then the problem is fixed... for a little while.
Please see the 2 screenshots below.
The 1st screenshot shows WHAT SHOULD HAPPEN when I select either a linked video clip or a linked audio clip in the timeline -- the 2 clips (audio + video) are selected together.
The 2nd screenshot shows WHAT OFTEN HAPPENS RANDOMLY ON ITS OWN. Premiere Pro will just randomly decide to select the clip that I click on -- without also selecting the linked audio or video clip! Once this starts happening, it happens for ALL THE CLIPS IN THE ENTIRE SEQUENCE! Then, I am forced to quit & relaunch Premiere Pro -- and the problem fixes itself.
Thoughts on how to prevent this problem from happening?
    Mike_Abbott
    Mike_AbbottCorrect answer
    Mar 3, 2017 11:48 AM UTC
    An old thread - but I've also experienced this with CC 2017...
    My feeling is it is related somehow to the Ctrl-K (windows) shortcut for making a razorblade cut, as mentioned above.
    This is a bug that needs to be squished...  heading over to the bug report form.
    Sep 10, 2026 9:47 AM UTC
    Long time Premiere user (9+ years). The random video and audio unlinking just happened on my timeline (Macbook Pro M1 mid 2020, Sequoia 15.7.7, Premiere 25.6.6 build 5, 20Mo project). All the footage is on an external drive. This bug already occurred to me with different projects and footage as well though, last November for exemple when I was editing another tv series.
    Quitting and relaunching Premiere did not solve the problem, I could go back and grab an autosave but this is too time consuming versus relinking every clip.
    Wanna let you know that this bug is still out there.
    Kaxmerkhoff
    Nov 8, 2024 5:34 PM UTC
    this wrongly says SOLVED at the top, which it isnt. needs to be upvoted. have had this happening with no fix on a project in 23.4., intel i7 mac, and now again premiere production 24.5., m1 max, in both cases footage is on network attached storage via 10gbe (once fibre channel to server, the other thunderbolt 10gbe to QNAP nas). INCREDIBLY FRUSTRATING BUG
    FunFürFelix
    May 2, 2024 5:04 PM UTC
    THIS IS HORRIBLE!!!!
    This bug occurred to me on multiple occasions in the past two months on timelines with as many as eight different cameras. The absolute worst part is that I have absolutely no idea why this keeps happening and when it has happened. This bug needs to be addressed ASAP! Relinking an entire 20-minute project is not an option. Working without linked clips is the biggest pain.
    Suggested solution:
    1. FIX THE DAMN BUG
    2. Add a warning box to Premiere, that can be deactivated or customized to a custom number, that warns you about the unlinking of clips. Example: X amount of clips have just been unlinked. Do you really want to unlink X amount of clips?
    eowyn723
    May 2, 2024 9:48 PM UTC
    A warning would be nice! I don't know if you'd be able to undo it anyway, but you never know when it happened so it's usually too far back in the history to undo to, even if it were possible. I can't believe this is still a bug. The first post on this issue was from 2015! I think nearly a decade should be enough time to fix the bug.
    Jan 22, 2024 12:19 PM UTC
    Just flagging this as I hit this issue quite regualraly in CC24 - Jan 2024 and still happening. Some timelines are 4 hours long for me as I begin to make assembly selections for a large documentary edit. Big problem at times! TIme consuming to remedy it
    Mar 28, 2024 10:30 PM UTC
    Wanted to back this up, this is a problem I've encountered in the March 2024 build of Premiere, with no warning it unlinks all audio tracks. And clearly this is a bug, because it does it gradually - one half of the timeline will still have linked audio tracks, the other side all the tracks have become separated, and then as you click around it spreads until all the tracks are unlinked! Really really really irritating.
    Mar 28, 2024 10:43 PM UTC
    After manually relinking the audio tracks, copying and pasting video clips will cause some of the audio tracks you've just relinked to unlink again. A cruel and unusual torture
    Jul 30, 2023 4:24 PM UTC
    I'm having the same issues still in 2023 with CC 2023, it's definitely linked to the razor tool, and when I have 7 video tracks, 15 audio tracks that I cut at once, it's multiplying my editing time by 3 with how much I have to fix everything manually or reimport audios with matched frame or whatever. This is a very annoying bug and has been for years.
    And there's no solution on the internet...
    We need a "Reimport all audio" or "Relink All" feature or something to help prevent this, or just need to find the origin or the issue please Adobe.
    eowyn723
    Aug 20, 2023 10:21 PM UTC
    This just happened to me in a 90 minute timeline and it's an absolute NIGHTMARE. And if I see one more suggestion to "click the linked selection button".... ADOBE FIX THIS
    eowyn723
    Aug 20, 2023 10:30 PM UTC
    Also how do we draw attention to this bug to the developers? There doesn't seem to be a good bug reporting form or anything? After this project is finished I am never using Premiere again because it's so rubbish that this keeps happening.
    Mar 6, 2023 9:22 AM UTC
    SOLVED: Click on the link icon between the magnet and spanner top left of the timeline (left middle of screen). This solved it for me immediately.
    Sep 16, 2023 3:45 PM UTC
    Yes, to make it more clear, attached is a screenshot. Doesn't seem like this is a bug but a feature. You can link and unlink by turning on and off the icon / button.
    maxbuzin
    Jan 17, 2022 11:57 AM UTC
    17/JAN/2021
    Had today the same issue...
    To fix it I've made a cut (not with the razor one). then the audio/video became unlinked.
    • Then selected both video and audio > right click > link. Obviously to link them.
    • After that, clicked to toggle OFF then ON the "Linked Selection"
    • Then clicked to toogle OFF then ON the "Toggle the track targeting fot this track" for both video and audio...
    • After that I closed the Premiere and relaunched it.
    It's working now... maybe some bug...
    Feb 23, 2023 2:59 AM UTC
    Hello everyone,
    Im having this issue in 2023. Version 23.2
    I updated thinknig that was the issue, i tried every one of the fixes in this thread. But it still randomly unlinks. My theory is that its linked to Command S (whenever I save it seems to be an issue) also no denying that i use the razor tool (Command C) a ton for my workflow.
    I have so many clips and for this to be an issue on a 20min project file is unbelievable.
    nate.schief
    Jul 21, 2023 6:46 PM UTC
    Having the same problem but I narrowed my problem down to every time I ripple delete everything unlinks.
    Jun 18, 2021 5:13 PM UTC
    ITS BEEN YEARS AND THIS STILL HAPPENS BUT I FOUND A FIX!!!
    So this "V1" track , where my clip was, was unselected. I was using ctrl+k for clipping, but it would only cut the audio, and would automatically unlink the clip. But once I selected it, it would cut both.
    So! Make sure whatever you are clipping, that the track is selected (targeted), and it will work.
    mriurbn
    Sep 26, 2020 3:50 AM UTC
    Hi there, I have the same problem. But I tried duplicating my timeline and all the clips relinked in the new timeline. Fingers crossed this helps!
    Apr 3, 2020 6:15 PM UTC
    I am still having this issue today I've tried everything and my linked selection is on and it still will not work.
