scotty321
Oct 10, 2015 2:24 PM UTC
Video and audio tracks unlinking on their own?
Has anybody experienced this very bizarre problem with Premiere Pro CC 2015.0.2? (I'm using Mac OS X 10.10.5.)
Several times per day while working with Premiere Pro, the "linked selection" option randomly stops working. The only solution that I have found for this is to completely quit & relaunch Premiere Pro... but then the problem comes back a little while later.
The problem is this: Even though the "Linked Selection" option is selected for my timeline, if I click on a video clip, the linked audio clip DOES NOT automatically select with it! If I click on an audio clip, the linked video clip DOES NOT automatically select with it! Even if I hold down the option key, the video & audio clips will not select together. This happens for ALL THE CLIPS IN THE ENTIRE SEQUENCE! I am forced to quit & relaunch Premiere Pro, and then the problem is fixed... for a little while.
Please see the 2 screenshots below.
The 1st screenshot shows WHAT SHOULD HAPPEN when I select either a linked video clip or a linked audio clip in the timeline -- the 2 clips (audio + video) are selected together.
The 2nd screenshot shows WHAT OFTEN HAPPENS RANDOMLY ON ITS OWN. Premiere Pro will just randomly decide to select the clip that I click on -- without also selecting the linked audio or video clip! Once this starts happening, it happens for ALL THE CLIPS IN THE ENTIRE SEQUENCE! Then, I am forced to quit & relaunch Premiere Pro -- and the problem fixes itself.
Thoughts on how to prevent this problem from happening?
    Mike_Abbott
    Mike_AbbottCorrect answer
    Mar 3, 2017 11:48 AM UTC
    An old thread - but I've also experienced this with CC 2017...
    My feeling is it is related somehow to the Ctrl-K (windows) shortcut for making a razorblade cut, as mentioned above.
    This is a bug that needs to be squished...  heading over to the bug report form.
    Jan 24, 2018 6:52 PM UTC
    I'm not sure this will be the "perfect" fix, but it did seem to clear up most of the linking issues I've been having:
    "Linked Selection toggle button available from Timeline
    Premiere Pro provides a Linked Selection command that can be applied to all open sequences in the Timeline panels. You can use the Linked Selection command as a toggle that you can turn on and off. Linked Selection is turned on by default.
    The Linked Selection command is available as a button from the Timeline, and from the Sequence menu. You can also assign a keyboard shortcut to this feature.
    When Linked Selection is turned on, clicking a linked clip in the Timeline automatically selects all the associated tracks. For example, if you click the video part of a linked A/V clip, the audio is automatically selected.
    When Linked Selection is turned off, only the single track item that you click is selected, and not all the associated tracks.
    You can temporarily override a toggle state by pressing Alt (Win) or Opt (Mac) while selecting the track. For example, if Linked Selection is turned on, and you press Alt (Win) or Opt (Mac) while selecting a linked clip, only the single track that you click is selected."
    adumi
    Dec 29, 2019 7:50 AM UTC
    Same problem of unlinking video and audio while using ctrl-k to cut in Premiere v.12 windows 10 64bit regardless of linking toggle turned on.
    Aug 17, 2017 9:16 PM UTC
    I'm have the same issue with Premiere 2017 Windows 10.  When I drag a clip into the timeline, and without manually unlinking, the audio and video move independently. NOT Ideal! It's helpful when I don't want the clips linked, but I generally work with audio and video in sync.
    bumpeboy
    Aug 9, 2017 2:07 AM UTC
    Am having the same problem.
    Premiere 2017 Windows 10 all my videos and audios are unlinked by default and worse is that I cannot, link them manually. If i select a video and an audio then righ click select 'link' they dont link.
    melissad49097869
    Jul 18, 2017 3:13 PM UTC
    also having this same issue in CC2017 on Win 10 pro 64-bit.
    Just opened a project I hadn't worked on in a few weeks and in one sequence *all* the video clips are unlinked from their audio component without me having done anything.
    And the worst part is, there's no option to select all and then hit re-link. You have to go back and do each clip individually.
    Jul 19, 2017 4:11 PM UTC
    Hi MelissaD,
    Sorry about the pain. We have a similar bug filed but I would like more info, if you don't mind. What kind of footage is this with? Which camera was the footage shot on? Was this a new project or an updated one? Let us know.
    Kombi Life
    Jul 30, 2017 3:51 PM UTC
    Kevin, I'm having the same issue with footage randomly unlinking on the timeline.  Also copy and paste linked media from a different sequence is pasting as unlinked.  Footage is AVCHD, project is a new one.  Hope that helps
    Ben
    Mike_Abbott
    stefan_gru
    Mar 3, 2017 6:52 PM UTC
    Others on this thread to log this same bug to help the product team weigh its importance: Feature Request/Bug Report Form
    May 2, 2017 5:00 PM UTC
    I see this thread's last response was in March. Just updated premiere last night and am now encountering same problem. Most of my sequences in my current project have linked clips but the one I am working on now has all clips unlinked which is a total hassle. Guess that bug still needs to be squished.
    michaels77529277
    Oct 15, 2015 7:33 PM UTC
    I'm also having this problem.  I notice it mostly when I'm using the cmd-K shortcut to make a cut in both the audio and video of a linked clip.  It frequently happens that only the audio or only the video is cut and this essentially makes the shortcut useless as I then have to either ctr-click on the clip to select "link" from the context menu and then cmd-K again or use my mouse to manually blade the portion of the clip that was not cut.  Surprising how frequently this has been happening in the past couple of days.
    scotty321
    scotty321Author
    Oct 15, 2015 7:47 PM UTC
    Very interesting. I never knew about that command-K shortcut, so this strange "unlinking problem" seems to be happening under a WIDE VARIETY of circumstances. Surely, this must be a gigantic bug in Premiere Pro. And I'm pulling all my hair out over this one!
    Oct 15, 2015 8:33 PM UTC
    I've found (at least in Windows) that you do not have to select any tracks for the Ctrl-K (command-K in Mac) shortcut to make a cut whenever to move to a spot on the timeline. But if you wish to make a cut on different items in the timeline, you have to choose the tracks.
    Also, you can link by right clicking the centre icon under the time code in the timeline. See circled grarphic.
