Weird behavior when using gyroflow + transform
  • January 14, 2025
  • 620 views
I stabilized a video with Gyroflow and pre-composed it, then I applied a transform effect and tried to make a zoom animation. However I get this weird behavior where The clip gets distorted with a green bg. How is that possible? Is the Transform effect affecting the Gyroflow plugin even Inside the nested sequence? If I turn off the transform it goes back to normal
jamieclarke
Hi @Lucas Samuel Zanchet - What version of gyroflow and Premiere are you using?
Please see, How do I write a bug report?
If you see weird behavior with a plugin you should contact the developers of the plugin and ask if they have seen your issue before.
Ok, the green in the back is because of the proxy, but the distortion stays even after detaching them
