afk.anxrchy
Resuelto
When saving a MBL Look, its saving as ".rgx". How to save it as ".mblook"?
  • May 22, 2021
  • 7 respuestas
  • 11793 visualizaciones
Hello! Me again, I downloaded a MBL look file and its ".rgx" and the only apps I know that support the importing of ".rgx" is Premiere Pro and After Effects. I am working on a project in Sony Vegas Pro 18 and SVP 18 can only import ".mblook" so I want to convert it, I've seen a lot of videos where people export Looks as ".mblook" automatically so I imported the ".rgx" and exported it, but its exporting as ".rgx". I tried importing and exporting using Premiere Pro and After Effects, but still its importing as ".rgx". I want to export it as ".mblook". What do I do? I want it converted soon, though. Thank you so much!
Este tema ha sido cerrado para respuestas.
Mejor respuesta de afk.anxrchy
If you face this issue, it is not an issue. It is just a misunderstanding. The MBL plug-in installs into plug-ins. One "Magic Bullet Looks" which is the old looking one which can't import looks and the other, "Looks" this is the new looking one with an import button. "Looks" is what you have to use. If you use the "Looks" plug-in, you can import and export. Anyways, thanks for the support! Enjoy!
7 respuestas
Anyone know how to help me? I am using after effects and the old colorings I downloaded now say .rgx (those ones work and I can use them) but the new ones I've just downloaded say .MBlooks and won't show up in app.
Also I use after effects 2020 version.
You would need to use those in the Magic Bullet Looks plugin ... as far as I know.
i used looks toooooo idk why its not working help me
for me toooooooooo bro
You can only import those into Magic Bullet Looks itself, as far as I know. So that's a thing to work within Red Giant's support.
No idea. As noted, the MB Looks panel only makes rgx files on my PC. Which on opening in Notepad, look more like a preset type file than a LUT anyway.
I think you'd need to ask the Maxon/RedGiant support about that.
On my PC, the .rgx files are what the Magic Bullet Looks panel exports. The only place I know that can use them is the MB Looks panel itself. You can't even use them in the input LUT slot in Colorista IV, which only accepts .cube LUT files.
From what I've read online, the Mblooks files are more of a "preset" than a LUT file, and my guess is they'd only work within the RedGiant panels that create/use them.
afk.anxrchy
Well how do I export MB Looks as a ".mblook" preset instead of ".rgx"?
Premiere does not generate mblook's.
Guessing you need MBL installed with Premiere.
afk.anxrchy
What do you mean? What do you mean installed "with" Premiere? MBL is a Red Giant Plug-In which I installed....
You will have to ask Red Giant.
afk.anxrchy
Why is the whole adobe staff not replying to any thread????
Peru Bob
quote
By @afk.anxrchy
...Because this is a user to user forum with only occasional appearances by Adobe staff.  We are mostly volunteers that are Adobe software users like you, not Adobe employees.
@mgrenadier is not an Adobe employee and as such can only be on the forums when not at his "real world" job.
I'm sure he will respond if he is able to help.
afk.anxrchy
Oh, I didn't know, I thought they were all staffs, thank you for letting me know. Can you help me though?
afk.anxrchy
@Michael Grenadier can you help me?
