dant35204461
해결됨
How to render still frame or animated PNG with transparent background?
  • July 3, 2023
  • 2 답변들
  • 3861 조회
Is anyone familiar with how to make the background of a PNG render transparent? I recall doing so in Painter but it seems that Stager is a bit different.
Any and all help is appreciated, thanks!
최고의 답변: Cyril Dellenbach
Hi @dant35204461,
Thanks for the question,
There's currently no solution to render a .PNG image with transparent background. With that being said, when rendering as .PSD, the Rendered image and the Background are separate layers.
Best regards,
2 답변
hello @dant35204461 the way I solve for this is by going into photoshop. Using Automate > Batch and then use a custom action that you setup in Photoshop. The action is really quite simple, create a new action, name it "Png Transparent" And then start recording. All you have to do is hide the background layer, save as a png, and then stop recording. Now close the file and run the new batch action that you just created, you can find this under the Automate > Batch setting. also make sure to choose the folder u want to batch edit and the folder you want as the output. cheers!
perfect! thanks man
Cyril Dellenbach
Hi @dant35204461,
Best regards,
Cyril Dellenbach (Micro) | QA Support Artist | Adobe
