Having issues with Add-On Tool not appearing and not being able to use my custom Stamp after update.
  • June 19, 2023
  • 1273 views
I am trying to figure out how to get my "Add-On Tool" feature to appear after the most recent update. When version 23.001.20093 of Acrobat was released I was able to use the following path C:\Users\(your user here)\AppData\Roaming\Adobe\Acrobat\DC\Stamps to add my stamp pdf and I used the following the path C:\Users\(your user here)\AppData\Roaming\Adobe\Acrobat\Privileged\DC\Javascripts (I created the folders Privileged, DC, and Javascripts) for my JavaScript. This was wokring and I was able to add my custom stamp using the "Add-On Tool" feature until the most recent update ( 23.003.20201). I have done nothing except update Adobe Acrobat DC. I no longer have the "Add-on Tool" feature appearing under the tools tab. In short, I need to get access back to the "Add-On Tool" feature in Acrobats most recent update 23.003.20201. Thanks in advance!
Hi All,
Hope you are doing well.
We acknowledge that the new Acrobat represents a notable change; however, we hope that as you get familiar with the new interface, you can be more productive and get more out of Acrobat.
We are actively working on all the currently unavailable features, such as customizing the all-page display, navigation & zoom tools such as 2-page view, 2-page with scrolling, marquee & dynamic zoom, etc., from the bottom right menu. And we will address them with the highest priority.
As you get more comfortable with the new interface, please contact us with specific questions on tools, features, or functionalities. We’re happy to provide helpful resources and answers to your questions.
If your critical workflows are impacted, you can switch to the old UI from the “Menu” on the top left corner of Windows and View Menu on MacOS. We will follow up with a detailed community-featured post, guiding you to familiarise yourself with the new interface and regular updates on upcoming changes.
Tariq Ahmad
ZackowskiAuthor
I believe I figured out my issue. I could be wrong but seems like the "Add-On" tool may have been replaced with the "Create-Custom" tool. All I had to do was change my view back to the old layout and it seemed to work just fine.
AkanchhaS8194121
Hi @Zackowski
Thank you for taking the time and sharing your findings with us.
With the latest UI, a couple of tools have been repositioned for a better experience. All have been added under one umbrella.
To bring back the old UI,
  • Click on the hamburger icon in the upper left corner.
  • Click on Disable New Acrobat
You can share your feedback about Acrobat's new view with our product team here https://www.adobe.com/products/wishform.html
Akanchha
