How to fix a SERIOUS lag issue for Acrobat and Reader on a Macbook Pro for forms? Please.
  • December 7, 2011
  • 61623 views
Both adobe reader 9 and 10 as well as Acrobat 10 are INSANELY slow on my brand new Macbook Pro when I try and fill out forms.
It laggs like crazy. I cant even believe how slow it is.
I have 2 gigs of ram available so thats not the problem.
I am also running the latest version on lion 10.7.2 i think
I cant find information on this anywhere and I am desperate. I was forced to download parrarels and use the windows reader and acrobat because this is just crazy
Someone please help
    Correct answer STCopper97
    http://superuser.com/questions/242576/adobe-reader-unusably-slow-on-mac-os-x-10-6-6
    The solution to my problem with lagging Reader and Acrobat were solved by following the above link. The only difference was I was not able to exclude RightZoom app from Adobe, so instead of allow a/exlcude this one. I excluded all/only allow these. If you have RIghtZoom app installed on you MAC (regardless of the version of OS you're using) this fix work. After 9 months of fustrations, problem solved.
    STCopper97Correct answer
    Holy crap. You have no idea how much youve helped, no homo but i love you. I was ready to call apple support.
    YESSSS!
    JR Boulay
    is the lag issue occurs with only one form*, some forms* or all forms ?
    If * : are they simple forms (one page, a few fields) or complex forms (many pages, many fields with many calculations) ?
    Actually, revently I have noticed that it is not just forms. Its all PDF documents. I ununstalled Acrobat X and tried just using Reader to preview the docs and same thing. I then uninstalled Reader 10 (or whtever the latest version is) and installed 9.4 and the problem still persists.
    The mac is having no problems other than that, it runs like a dream. But this Reader problem is driving me crazy. I cant even scroll through a document because its just so laggy
    JR Boulay
    Did you try to run Reader and/or Acrobat in 32 bits mode ?
    (Right-clic the app icon : Show info : then tick the 32 bits checkbox)
