In Acrobat Pro, is it possible for letters input in a text field to be automatically made uppercase?
  • January 15, 2024
  • 802 views
Further, is possible to restrict the text field to letters and hyphens?
Correct answer try67
You can do it using this code as the field's custom Keystroke script:
event.rc = /^[-a-z]*$/i.test(event.change);
event.value = event.value.toUpperCase();
JR Boulay
"is possible to restrict the text field to letters and hyphens?"
Only letters can be in upper case.
try67
try67Community ExpertCorrect answer
Thank you! I had omitted that the field should be able to accept spaces as well, but then adding a space to the character class, as follows, sorted that out.
event.rc = /^[-a-z ]*$/i.test(event.change);
Nesa Nurani
If you want to show uppercase as soon as you type it, replace:
with:
event.change = event.change.toUpperCase();
