So here's the thing. In the latest premiere update, 24.5, I cant copy the audio volume and paste the attributes to all my others audio clips, which helps me maintain the same volume for all my clips. In the case of audio effects, all pastes well. Any suggestions?
Make sure when copying the audio, only select the audio part of the clip, not the entire clip.
Then Paste Attributes will appear in the dropdown.
That's the version I'm using as well, and my experience has been the same. It worked normally for awhile and then stopped. Very frustrating.
I've been copy/pasting attributes between clips in my timelines for many years. I can no longer do this in my current project.
I'm in version 25.2.1 and this issue has gotten out of control. I've gone through the suggested fixes, even the ones marked "correct answer," and no fix. This includes, changing workspace layout, trashing prefs, and importing my project into a fresh project.
The strange thing is that my problem seems confined (at the moment) to mono tracks only, not stereo.
Would really appreicate a fix ASAP. Thanks.
Update:
Started a new project. Copy/paste between mono tracks worked great.
Went back to previous project (see initial post). Copy/paste between mono tracks still not working.
I expect it to stop working in my new project eventually. We'll see...
Having the same problem in 25.2.3 (build 4).
The only workaround I've found is to select the volume section in Effect Controls and then lasso/select multiple audio clips and cmmd+v (paste) in the timeline. This seems to work so far and doesn't add a second "volume" control in Effect Controls as others have mentioned. Hope this helps until it gets fixed!
Hi D&Z,
We fixed a similar issue in the 25.2 release of Premiere Pro. Would you mind sharing a screen recording of the issue you are experiencing? It will help us investigate the issue properly.
Sumeet
I am still having the same issue, and I'm using 25.2.3, build 4.
This issue has not been fixed.
Find more inspiration, events, and resources on the new Adobe Community
Explore Now
