New Participant
October 22, 2024
Dynamic Link Issues Between Premiere Pro and After Effects, System Hanging, and Importing Problems
  • October 22, 2024
  • 11 replies
  • 5801 views
Description of the problem:
I am experiencing multiple issues with Dynamic Link and file importing between Premiere Pro (Pr) and After Effects (Ae). Below are the detailed problems I have encountered:
  1. Dynamic Link not fully functional: I am unable to establish a stable dynamic link between Premiere Pro and After Effects.
  2. Unable to open Ae sequence in Pr: When I try to open an After Effects sequence in Premiere Pro, it fails to load or open properly.
  3. System hangs during file import: When trying to import an After Effects sequence (especially one with video) into Premiere Pro, my system occasionally hangs.
  4. Drag and drop issue: I cannot drag and drop files from Windows Explorer into the Premiere Pro project tab, which used to work normally.
Steps I have already taken to resolve the issue:
  1. I have completely uninstalled all Adobe applications using the AdobeCreativeCloudCleanerTool and performed a fresh installation of Creative Cloud and both applications.
  2. I installed the latest versions of Premiere Pro (Version 25.0.0 Build 61) and After Effects (Version 25.0.0 Build 53).
  3. I have tried running both Premiere Pro and After Effects as Administrator, but the issues persist.
I would greatly appreciate your assistance in resolving these problems as they significantly affect my workflow. If more information or logs are needed, please let me know.
New Participant
October 15, 2025
I accidentally fixed it when I was trying to clear up my Mac’s memory by deleting the cache in the Library. Not only did it free up over 200 GB of system data, but Dynamic Link also started working normally again.
New Participant
January 1, 2025
Adobe Dynamic link is not working I get a black screen
Bruce Bullis
Lots more detail, please. 🙂
Can you provide some idea of the steps you're following, which reliably reproduce a black screen?
New Participant
January 1, 2025
When I want to add a text effect and click on the link option between the two programs, a black screen appears to me and the program stops working Adobe Premiere I tried to turn off the device and restart it did not succeed The programs have updated to the latest version
danield42985907
New Participant
November 15, 2024
The fix for me was to open the file in After Effects and drag the composition from After Effects to Premiere Pro.
When I try to drag the file into Premiere from Windows Explorer, sometimes it hangs.
CCY1978
Same issue from my side.
With the latest updates, unable to import an AE comp  from "file/import" but it's ok from "File/Adobe dynamic Link/import an AE comp"
New Participant
October 24, 2024
I have identified that the issue occurs when both Premiere Pro and After Effects are open at the same time. When I run them separately, the applications work.
However, when they are both open simultaneously, the following problems occur:
Direct2D Drawbot error (HRESULT:...): This error appears when I change the video mode in After Effects (e.g., from Normal to Multiply, Screen, etc.).
Direct2D Drawbot error also occurs when I try to import QuickTime video files into the After Effects timeline.
These errors and the instability go away when either Premiere Pro or After Effects is closed, but when they are both open together, the problems reappear.
New Participant
January 6, 2025
Having the same problem since moving to '25 PR and AE. Obviously, closing AE in order to import compositions is not a long term solution. Abode, please get this fixed sooner rather than later.
New Participant
February 15, 2025
I am having this same issue with inability to dynamically link AE file into PrP.
New Participant
October 24, 2024
After further testing, I discovered that disabling certain panels in Premiere Pro resolved the import issue.
However, there is still a critical issue where my PC crashes and restarts when attempting to change the video mode in After Effects.
I have not yet tested the beta version to see if the issue persists there.
jamieclarke
Hi @Garis Lurus Std - There is a known issue in 25 with importing media, but I'm not sure if your issue matches.  Can you try using 25.1 beta and see if you are still experiencing these issues?
New Participant
October 24, 2024
- I updated After Effects to the latest version (25.0.1), but the issues remain the same.
- Downgrading both After Effects and Premiere Pro to version 24.6.3 resolved all the issues.
- After updating back to the latest versions and removing the old versions, the problems came back.
Hi all, I updated to Premiere Pro 25.0 and After Effects 25.0.1 and now the import of aep files is not possible anymore. I can find the aep files on my HD, select one of the compositions, the File import window appears but the progress bar stays with 0 %.
I tried to open the aep file with After Effects and saved it again but with no better result.
It would be very nice still being able to work with my After Effects animations!
Thank you for any help, Frank
Bruce Bullis
We believe we've already fixed this problem; can you successfully import the .aep into the current PPro beta build?
jamieclarke
HI @Garis Lurus Std - There is an update to After Effects today or tomorrow can you update and let us know if you are still experiencing issues.
There is an import issue in the known issues, please have a look and keep us updated.
