FAQ: How to fix "Display Acceleration Disabled" in After Effects
If you're running into a problem where After Effects displays a message on the Composition panel that says Display Acceleration Disabled, follow the suggestions given in this post to fix the problem.
macOS:
• Make sure your MacBook is connected to the power source
• Go to Preferences > Display and toggle Hardware Accelerate Composition, Layer, and Footage Panels
• Go to Preferences > Video Preview and toggle Enable Mercury Transmit
Windows:
• Update the on-board and dedicated graphics drivers of the computer. If this happens after updating the graphics driver, reinstall the previous version of the driver
NOTE: Nvidia driver version 442.92 seems to cause this problem on many systems. If you have installed this driver, please reinstall the previous version
• If your computer has Nvidia graphics, make sure to update the GeForce Experience software as well
If none of the steps given above help, obtain the System Information file (.NFO) and After Effects logs from your system and share them with us. Here is how you can do that:
Log files:
- Launch After Effects and go to Help > Enable Logging.
- Work in After Effects for a few minutes.
- Then go to Help > Reveal Logging File.
System Info:
macOS:
Follow the steps given in this article: https://support.apple.com/en-in/HT203001
Windows:
1. Hold the Windows key and press R to open the Run window
2. Type msinfo32 and click OK
3. From the System Information window, go to File > Save
4. Save the file as .NFO
After collecting both the files, upload them to Adobe Creative Cloud Files by following the steps given in this article (https://helpx.adobe.com/in/creative-cloud/help/share.html) and share the URL in the comments section below.
