Miti Abulaiti
New Participant
November 25, 2021
[HELP] Effects Control panel shows warning and the effect doesn't work [HELP]
  • November 25, 2021
  • 2793 views
There is a yellow triangle with exclamation mark in it on my fx control panel when I applied an effect to a path. and the effect doesn't work. what is the problem here and could anyone please help?
nishu_kush
Hi ablimita16284215,
Thanks for writing in.
Which effect is it? Is it a native effect and renamed it or a third-party effect? Do you get any message when you over the mouse over exclamation mark?
We're here to help, just need more info.
Nishu
New Participant
July 18, 2022
I have the same problem. It is a native effect and it does show a message
Mylenium
Brainiac
July 19, 2022
And what exactly? You need to provide proper info and not just raise your finger to say "Me, too!".
Mylenium
