HELP! My Character Animator Project Crashed and won't reopen
  • December 7, 2022
  • 1800 views
So I ran out of disk space while exporting a puppet and it caused Character animator to crash. Now it geve this error and won't reopen. I spent three days on it. Is there anyway to recover it? Are there any previous versions that I can recover?
Correct answer reverie555
dtull-adobe was able to fix it. It was mostly a matter of renaming the damaged projectdata.rope file in the repo.noindex folder. Once it was named back to projectdata.rope it opened fine. Also in the future. If you are exporting and run out of disk space and crash. Besure to free up your disk space before opening character animator back up.
Erica Schisler
We're looking for someone directly on the Character Animator team to help. We'll get back to you as soon as we find the right person.
reverie555AuthorCorrect answer
Unfortunately, that was my only idea. Sadly, I'm not very useful when it comes to technical issues. You can always reach out to Dan directly by clicking on his UserID and messaging him there. I'm just a volunteer here on the forum, so I really don't have much insight into the inner workings at Adobe. But I'll try and find if someone can help you.
Thanks again. I'll try reaching out to Dan directly. I'll post here if he is able to resolve the issue. But in case Dan is not available would appreciate any other help you can locate. Really appreciate it!
Welp. Went to customer support and after two hours, they were just like "Oh well,  it's damaged" WHY IS THERE NO AUTOSAVE IF THIS TYPE OF THING CAN HAPPEN?  Is there anyone from the Character Animator team that understands the file structures, that could help me retrieve this??
TheOriginalGC
I don't work for Adobe, so I can't help you. But there is a chance that someone that works there can recover the file. But try not to get your hopes up. You've encountered what CH uses for autosave already.
TheOriginalGC
The first thing to try is to hold down the "alt" key while starting to do a fresh start without loading the previous project.
That didn't work. Once the character animator is opened without a project opened, and I choose to open to that project. It gives the same error.
TheOriginalGC
Maybe someone with technical expertise can offer assistance in recovering the project. Otherwise, you would have to import the original file into a new project, which sounds like you're trying to avoid.
