alank99101739
MIDI for controlling Face and draggers
  • September 25, 2018
  • 5091 views
Has anyone experimented much with MIDI beyond an alternative for keyboard triggers? In particular, can they control draggers or the face angle? I came across Using Character Animator With Hot Hand Wireless MIDI Controller - YouTube which was pretty nice. Seems to support X/Y/Z spatial positioning for I think it was $50? I would love one on each hand to drag the character hands around.
I was looking at the HTC Vive API (same sort of thing, but much more expensive a bulky) - looks fairly easy to get position tracking of the two hand controllers, which could be a nice way to control puppet hands (via draggers). But same problem, I don’t see how to feed that into CH to control Draggers.
    Correct answer KJerryK
    Thanks Jerry. Interesting idea, but yes I would really prefer on draggers, especially with the v2.0 features around fixing double jointed arms.
    Can you control draggers from inside AE I wonder... It seems to be more extensible...
    I made another stab at using the x,y transform parameters, and here is what I got. So the Hot Hands could actually be worth a look, as using human arms might provide realistic physical limits to the motion. As for using midi to control animation in After Effects, there has been a lot of work done on that, but I haven't yet tried it myself, just watched some tutorials.
    KJerryK
    Hi Alan,
    That might be interesting to look at. But just using a midi device -- hardware or virtual -- provides fader controls along with key strokes. So any behavior that can be changed uniformly can be assigned a midi fader. This includes all the transform behaviors, most of the physics behaviors, face behaviors, and eye gaze. Also the midi fader controls can be recorded in a *.mid file to be played whenever needed. But, as you said with regard to the dragger, how to use midi there. The best I've been able to come up with is to assign a transform behavior to, say, just the arm, rig it appropriately, and then "drag" the arm using the rotation transform triggered by a midi fader control. That works okay, but my brief attempt looks a lot stiffer than using the dragger.
    alank99101739
    From what I could see of the Face behavior, you can put slides on lots of controls, but not the actual head rotation or forward/back - that can only be fed in via webcam that I can see. (Am I missing something?)
    Also I could not see draggers able to attach to MIDI signals, so I could not see how draggers could be controlled by MIDI sliders. That is the one that I think would be really cool - hook the X/Y of the "Hot Hand wireless midi controller" to a dragger and I can control hand positions of the puppet just moving my own hands. Sounds really useful for live streaming - using the mouse is a bit of a pain (and can only do one hand at a time).
    (For recordings, I still want my camera panning support however. Then I could record a long scene and chop it up afterwards (zoom in/out with camera, layer in some other scenes for variety etc). You can do it at present by adjusting zoom of everything by hand, but its a bit painful.)
    alank99101739
    First cut at somewhat working code is now in GitHub - alankent/htc-vive-midi: Turns HTC Vive controller positional data into MIDI events, for integration with Adobe …  MIT License. Needs more testing, but calling it a night tonight. Anyone who is a better C# programmer than I is welcome to help clean it up - particularly to put a GUI on the front instead of relying on command line arguments. Next step is an end-to-end demo...
    I don't have everything calibrated etc, but this video was done in a single take using HTC Vive controllers to control both arms simultaneously, and buttons to cause various facial expressions. The biggest issue is the hands do not rotate - but I am not sure if anything is changing here in Character Animator v2.0, so I might pause for a bit until that is available before doing more on this project.
