ian040504
I have some problem for install CS4 Design Standard......
  • July 11, 2014
  • 4109 views
My system is win8.
And I have a disc for install CS4 Design Standard Traditional Chinese version.
Whole process are fine......but it has something wrong at last......
It says: Install is complete,but has something error occur.
And the list of right hand side is "affected products"
In the lower left corner, it's "Information" or "detail" or something like that......
Its screen shot.↓
That message says:
"Adobe Flash Player 10 ActiveX
Error:
Error 2."
Can anyone told me what's wrong of my installation ?
Thanks~~
    Correct answer kglad
    i don't choose mcfee in that page ever......
    and...well......
    that error still occur when i install CS4 D. S. in response 10.
    but i can open that six programs who be affected after i close installation.
    and i'm not sure they work ok,or have some function can not work.
    and that situation is same with beginning......
    have a error message, but programs can be open.
    i don't know that installation process be ok or not.
    and i don't know programs work ok or not.
    if everything seems to be working, leave it.  if you have a problem:
    uninstall all the cs4 programs and use the cleaner per, Use the CC Cleaner Tool to solve installation problems | CC, CS3-CS6
    uninstall flash player, Uninstall Flash Player | Windows
    restart your computer.
    install indesign first.
    then install photoshop
    then install acrobat and illustrator
    then install the remaining cs4 programs.
    ian040504
    ian040504Author
    I uninstall my CS4.
    And I uninstall flash that suggested by the article.
    But it still have same wrong when I install it again......
    Is that flash 10 necessary?
    ian040504
    ian040504Author
    Oh!! It's work!!
    My CS4 work ok now.
    That message of error don't occur again.
    Thank you, thank you so much!!
