J_Kraft
Need Assistance : Creating a script - Using Data Merge info to adjust varying page sizes
  • December 2, 2021
  • 4 replies
  • 965 views
I am looking for help to create a script, that adjusts varing page sizes based on pulled in Data Merge info - the CSV file has fields for W & H, so I want to adjust the pages created from the merge, to be specific sizes, each unique in the created merged document.
e.g. - CSV file, Row 1 has "6" in the W column, "10" in the H column,  after the merged doc is created, page 1 would pull in all fields, and also set the page size to 6" x 10" in size.  Each page would be a different size.
I am new to scripting so I thought this would be a good first go at doing so.  I've started my research but don't find a whole lot in the way of combining data merge & scripting.  Would it be best to incorporate the action along w/ the merge, or after the document is created, create a script to resize each page based on a given field populated by the CSV file after the fact? ( <<WIDTH>> and <<HEIGHT>> created fields in the merge.
Hopefully that all makes sense -
Thanks!
Correct answer rob day
Hi @J_Kraft , You might be able to use an idleTask listener along with script labels.
Here my data is:
This example invokes the DataMerge menu item, labels the w & h text frames and adds an idletask:
//need targetengine for listeners
#targetengine "session"
app.scriptPreferences.measurementUnit = MeasurementUnits.INCHES
var mergeDoc, iTask;
var wLabel = "width";
var hLabel = "height";
var wData = "<<W>>";
var hData = "<<H>>";
//a boolean to get the merge document
var isMerge = false;
setLabels();
//invoke the datamerge menu, the Data Merge Panel needs to be open
var menuItem =  app.menuActions.itemByID(108036)
if(menuItem.enabled){
    menuItem.invoke();
    //set isMerge to true and listen for the idleEvent
    isMerge = true;
    //make a new idleTask. The task name and the sleep time 4 sec
    iTask = makeIdleTask("onMergeDocument", 4000)
    iTask.addEventListener(IdleEvent.ON_IDLE, onMergeDoc);
}else{
    alert("Open DataMerge panel and try again");
* Idle task function runs when data merge is invoked
* @param event
function onMergeDoc(e){
    if (isMerge) {
        //the merged document
        mergeDoc = app.activeDocument;
        iTask.remove();
        //resize the pages based on the w & h fields
        setPages()
* Resize the merged document‘s pages
* @return void
function setPages(){
    var pgs = mergeDoc.pages
    var api, nw, nh;
    for (var i = 0; i < pgs.length; i++){
        api = pgs[i].allPageItems;
        //gwet the width and heights
        for (var j = 0; j < api.length; j++){
            if (api[j].label == wLabel) {
                nw = Number(api[j].contents);
            if (api[j].label == hLabel) {
                nh = Number(api[j].contents);
        //Resize the pages, adjust as needed
        pgs[i].resize (CoordinateSpaces.INNER_COORDINATES,AnchorPoint.CENTER_ANCHOR,ResizeMethods.REPLACING_CURRENT_DIMENSIONS_WITH,[nw*72,nh*72])
    cleanup();
* sets datamerge field’s script label
* @return void
function setLabels(){
    var mapi = app.documents[0].allPageItems;
    for (var i = 0; i < mapi.length; i++){
        if (mapi[i].contents == wData) {
            mapi[i].label = wLabel;
        if (mapi[i].contents == hData) {
            mapi[i].label = hLabel;
* Makes a new named idleTask
* @param the task name
* @param the sleep time
* @return the named idleTask
function makeIdleTask(n, s){
    var it;
    try {
        app.idleTasks.add({name:n, sleep:s})
    }catch(e) {
        it = app.idleTasks.item (n);
    return app.idleTasks.item (n);
* Remove the w & h text frames
* @return void
function cleanup(){
    var api = mergeDoc.allPageItems
    for (var i = 0; i < api.length; i++){
        if (api[i].label == wLabel || api[i].label == hLabel) {
            api[i].remove()
The resized merged pages
rob day
rob dayCommunity ExpertCorrect answer
Here my data is:
setLabels();
    menuItem.invoke();
    isMerge = true;
}else{
* @param event
    if (isMerge) {
        iTask.remove();
        setPages()
* @return void
    var api, nw, nh;
    cleanup();
* @return void
    var it;
    try {
    }catch(e) {
* @return void
function cleanup(){
            api[i].remove()
J_Kraft
J_KraftAuthor
Hey there Rob!
Thank you!  I got the script to run, and it looked like it was working like magic! - it took a moment to resize all the pages (in this case there are 42 records in the CSV), and then immediately crashed ID.  Could it be something to do with it merging from a CSV file, and one w/ headers for that?
So close!
brian_p_dts
Another alternative approach would be to roll your own DataMerge with a custom CSV parser and build the pages on the fly, with varying height and width per row.
J_Kraft
J_KraftAuthor
As someone who is just getting started writing scripts - by any chance of a good resource, or a script I could Git to monkey with that you might recommend to Frankenstine together?
Another apporach could be using a pre processing script which does the following
  • Parse the csv and get the values for W and H for the record no. n
  • Resize the pages as per the values got
  • Call the datamerge for record n
  • Repeat the process for all the records
This approach would be less complex than the previous one but both approaches have their pros and cons
-Manan
In my opinion, you will have to run a post processing script that runs after the merge is done(either via scripting or manually). Now for this script to resize the pages, you would have to identify the value of W and H in the merged document. How you identify these values would depend upon how your document has been setup and the incoming data, some of the scenarios that I can think of are mentioned below
  • If these values are placed inside individual textframes, then you could add labels to these frames. Once the merge is done you can iterate the collection of frames on each page check for label, identify the width and height values and do the needful resizing
  • If these values are embedded in between other text, then identify a search pattern that will work for the resultant text which you can use as a search string for Grep find, then find the values and do the resizing.
I hope this makes sense and did not confuse you more
-Manan
J_Kraft
J_KraftAuthor
Great! Thank you for the start of how to think about setting this up.
I'd be interested to see if anyone has an alternative approach.
