The easiest way to get text into a text frame on top of another text frame
  • June 21, 2021
  • 8 replies
  • 4515 views
I’ve been using InDesign all the way since the first versions, and I mostly enjoy it. There is however one small but nagging issue that has bugged me this whole time, since switching from QuarkXpress 3.31 or thereabouts ... I decided to make a last effort to try to investigate the rational way to do the following operation which I probably do more than a dozen times a day.
Here it goes: Let’s say you have a big text frame on a page, typically the main text area of a book. On a specific place on top of this, I’ll inevitably want to put some text. I know exactly where, so I start by pressing cmd+f and draw a frame. Then I press t to get to the text tool, and click inside the new frame to convert it to a text frame and start typing or pasting. But no luck - the text always goes into the text frame behind.
There are workarounds of course, like drawing the new text frame extremely wide, enough that there is an area outside the frame behind it to click on, so as to ‘force’ the text into the new frame - as I always have done it since Indesign 1.0 -- muscle memory by now, but it’s still irritating to have to resize the frame afterwards. Locking the frame behind it also too much hassle -- there may be multiple frames to lock, this needs to be a quick operation.
The easiest way that I have managed to find, is probably this:
1. Draw frame
2. Go to the Object menu, choose Content > Text
3. press t for text tool, and THEN click inside the new frame, and
4. start typing
I can even make a keyboard shortcut for the Content > Text part, and do this thing more rationally than I have all these years, but I will still be nostalgic about how easy this used to be in Quark 25 years ago. Am I missing something? I hope so!
jmlevy
Do you know this trick?
Start to draw your new text frame (with the text tool) outside of the area of the existing one. Do not release the mouse and press the space bar: you will be able to move the new one over the existing one, and you can continue to size it as you want
Neat and handy trick! I didn't know this.
(And it gives me a faint hope that someone who was smart enough to code this, also could think of a way to even let me start the drawing of the new text frame inside the area of the existing one).
rob day
If you try the script make sure the text frame you are trying to align with is selected.
rob day
Hi @oysteinvidnes , Can you show an example where you need the two text frames? It doesn’t sound like you are trying to anchor the new text frame into the existing frame’s textflow. Why not simply format the text in the existing frame?
It would also be easy to script, something like this:
var b = app.documents.item(0).selection[0].geometricBounds;
var tf = app.documents.item(0).textFrames.add({geometricBounds:[b[0],b[1],b[2]-(b[2]*.75),b[3]]})
app.documents.item(0).selection = tf;
If something is scriptable, it doesn’t usually make it in as a new feature.
Thanks for the input. It is certainly amazing what you can do with scripting, and this one really may come in handy one day. It is however quite far from what I (in vain, perhaps) am trying to convey here. When designing a page, you want to treat the page as a canvas. You might start by drawing up the area for the main body text. Sometimes this will be broken into two or more columns. You set up the margins and you quickly draw a text frame within them. One day you even might draw up a three column grid, and in smack in the middle you want to put a quotation. See screenshots. There are many, many, innumerous ways in Indesign to do that. But the most obvious and quick one – to draw the text frame the same way that you drew the main one – is off limits. So you have to work around it.
It’s not even hard to do, it just takes a few more clicks. But the program works against you here in at least one further way you don't expect.The text tool can't draw a new frame as long as there is unlocked text in the background. Your first quick instinct may be to draw a frame with the frame tool instead. Yeah, that should do the trick, no problem, you draw the frame and switch to the text tool to put the text in, like you would normally do. But the text tool refuses to convert the new frame to a text frame as long as you don't lock the background frame first, or manually assign text to the new frame.
These are my only and quite limited complaints. And the only reason I have it, is the fact that I find Indesign generally a quite consistent and logical program. Of course everything I am trying to point out here is scriptable, some way or other, but if I need to make a script to draw up a page then I am out of business.
rob day
I would use a paragraph style so the quote travels with the text and other instances can be consistently created and updated.
Oh. And when done, best post the link to your request here in this thread so that others who come accross this thread are able to find it and finally up-vote at InDesign UserVoice.
Uwe Laubender
( ACP )
Ah, yes, of course. Here’s a link to the feature request. Thank you!
Or yet another way:
Select a single character in your main text.
Copy.
Press the Esc key.
Paste.
InDesign will create a "standard" text frame sized 150 Pts x 150 Pts containing the copied text in the center of your visible layout window.
Uwe Laubender
( ACP )
Thanks for all the great suggestions! Appreciated! But I'll still play hard to please – this shouldn't require a song and a dance, and could have been really easy with just a small adjustment: When hovering the text tool above an empty area, the tool turns into a text frame tool, as indicated by the cursor. However, when hovering above an existing text frame all you can do is place the text cursor – no way to make a new frame. But the ‘text frame tool’ could be invoked by a mofier (alt, fx?), to make it possible to draw a text frame on top of another?
Alternatively, the text tool could stop ignoring empty, unassigned frames that sit on top of text frames?
Until then ...
When using the copy-paste trick above, as you say Indesign puts the pasted text into a standard text frame in the middle of the screen. But I don't want to have to move and resize frames after creating them, which requires at least double amount of clicking and movement than just creating a frame where I want it.
Locking and unlocking object(s) is pretty easy, of course, and I should probably do it more. But sometimes there already are a few locked objects on a spread and I don't want to unlock them all after creating my new text frame. Then again, I should have put the other locked objects in a locked layer instead. I digress.
But I'm really happy that there is a forum with members that read and try to solve such a silly boring little riddle. Thanks! At least my debut here made me rethink how I should do it, and I think I'll stubbornly stick to my new way of putting one text frame on top of another, though I can see how others may find the other ways preferable:
- Press Esc key (to get out of typing/text editing mode)
- Press f key for frame tool
- Draw frame
- Press custom made shortcut to assign text to frame (I use ctrl+t on my mac)
- Press t for text tool
- Click inside new frame and paste or start typing
I wrote: “the ‘text frame tool’ could be invoked by a mofier (alt, fx?), to make it possible to draw a text frame on top of another?” – but I realize now the alt-modifier is already (somewhat) occupied by the hand tool. And alt+shift invokes placement of a note. So I don’t know. But using alt to invoke the hand tool is erratic anyway, it only works when you are editing text, and not before the text cursor is properly placed, so I always use alt+space instead.
Hm…
Yes, I see what you struggle with.
Try this:
Select the main text frame and set it to locked.
( Keyboard shortcut Strg + L on my German Windows machine. )
Draw the new text frame with the text tool.
When done use the keyboard shortcut to unlock everything on the spread, Strg + Alt + L in my case.
Depending on your machine and OS the keyboard shortcuts could be different.
Cmd + L or Ctrl + L and Cmd + Alt + L or Ctrl + Alt + L.
Maybe the easiest* thing:
Pull out a text frame object from an open InDesign library or an open CC Library.
* Perhaps not, because any frame asset will remember its layer name when it was added to a library.
To get around this you first have to disable the option "Paste Remembers Layers" in the Layers panel.
Uwe Laubender
( ACP )
BobLevine
Lock the main layer, create a new one, put the text frame there.
That works, of course, but it still makes me think it could be so much easier. If the new frame has any kind of color property (like a background color or a stroke around it), it works exactly the way I expect it to: clicking on it with the text tool converts it into a text frame. But if it has no properties, and there is a text frame behind it, the new frame is ignored by the text tool.
Another workaround could be using object styles to first give the new frame a property, and then to take it away again. Pretty quick, and less clicking, but still something I would have to set up for each and every new document.
BobLevine
Why not draw the frame with the text tool?
Sorry, I meant ‘pressing f’ -- not ‘cmd+f’!
