Copy and Paste settings doesn’t seem to be copying correctly
  • July 12, 2022
  • 4 replies
  • 2017 views
I am working on a Hyperlapse in Lightroom Mobile on my iPad Pro and I have my main photo edited how I would like it to look so when I copied the settings and then pasted them to the next photo, the one with the pasted settings doesn't look as vibrant as the "main" photo. I made sure to select all the boxes on the settings page that I wanted to be pasted onto the next image or images and it just doesn't look like the original at all. What would be causing this to happen? I will say at first I noticed I everything checked except masking. So I checked that box then attempted another copy and paste thinking the masking being selected this time would fix that and it didn't really change anything. I saw very little difference.
Thoughts?
Correct answer JP Hess
Without seeing the two images it would be difficult to really say. However, in order for such a process to work, the second image to which the settings are being pasted would have to have the exact same characteristics as the first image. If the dynamics of the second image are different in any way then pasting adjustments from another image will not produce the same results.
lorettaw46398476
did you ever figure this out? mine is doing the same
Im having this same issue 😕😕
same problem and its killing my editing process
JP Hess
Hard to say. I'm not a real technician. Beautiful image, by the way. If it were me, I would simply use a filter (the Select Sky option) and then increase the saturation and do whatever else was necessary to enhance the sky to get the effect and not worry about it. But then, that's me.
JP Hess
JP HessCorrect answer
I should have posted images in my original post. Photo 1 has all the edits. Photo 2 is right out of the camera with no edits applied. Photo 3 has the pasted settings from Photo 1. Look at how vibrant the sky looks in photo 1 compared to photo 3. The city skyline doesn't look as bright in photo 3 as it does in photo 1.
