Francis-Crossman17221443
Principal Product Manager
November 25, 2021
해결됨
FIXED: Export issue for H.264 and HEVC with Premiere Pro 23.1
  • November 25, 2021
  • 35 답변들
  • 141983 조회
This issue has been fixed in Premiere Pro version 23.2.  Please update to get the fix.
We have identified a file name issue affecting H.264 and HEVC/H.265 exports on Windows with Premiere Pro 23.1
The issue impacts H.264 and HEVC/H.265 exports to folders with names that use double-byte characters, such as Chinese, Japanese, Korean, or extended ASCII characters, like accents and umlauts. Affected users will see this message: File importer detected an inconsistency in the file structure of %filename.mp4%. Reading and writing this file’s metadata (XMP) has been disabled.
If you are experiencing this issue, use one of these options:
  • Please update to version 23.2 where the issue is fixed
  • The following workarounds are for 23.1
    • Choose an export destination folder that uses only single-byte ASCII English characters (no accents, umlauts, etc.)
    • Export to a different format, such as Apple ProRes.
    • For H.264 exports only: disable hardware-accelerated encoding.
이 주제는 답변이 닫혔습니다.
최고의 답변: Ann Bens
Update to 23.2.
35 답변
Rıfat Dirgenali
When I restored version 23.0 the problem went away
After the latest update I have the same problem. I use H.264. I have plenty of storage space on my harddrive, so that is not the problem. I have changed to Mercury Playback Engine Software Only and use Software Encoding in Export settings. Still doesn't work. I have also tried different Bitrate settings.
The only thing that works for me is when I export to an external drive or even the SD card. Just so you know 🙂
(I live in Sweden.)
December 15, 2022
The workaround is actually disabling hardware-accelerated encoding in the export window. Toggle open the video section and find Performance under Encoding settings.  Change it to Software Encoding.  Hope this helps.
That did not work for me. I restored to version 23.0 and now it works.
Kirmm Ella
The problem I had is that the name of the export folder had non basic English characters. After changing it the problem went away.
December 14, 2022
@10295028, thanks for letting us know this worked for you and you were able to get your project exported.
wsl3825377
after update to 23.1, cannot export file, it shows an error
"File importer detected an inconsistency in the file structure of filename.mp4. Reading and writing this files metadata (XMP) has been disabled."
I need to install old version (23.0) to solve the promlem
After working for quite a while successfully exporting parts from a footage, suddenly for no clear reason I failed to continue do so and got the error message saying:
" File importer detected an inconsistency in the file structure of 2018.mp4. Reading and writing this file's metadata (XMP) has been disabled".
The source footage I was working on was created by premiere earlier.
The same happened with some other footages of the same nature in different projects in different hard drive locations.
Restarting the computer didn’t help.
My premiere Version 23.1.0 (build B6)
What should I do? Will reinstalling premiere help?
System info:
Core i7 10700K Up To 5.0GHz Eight Core 16MB 3Y CPU10700K
16GB DDR4 3200 3Y DD416GB32
NVIDIA GeForce GTX1660 Super 6GB 3Y GPU1660S
Intel Z490 Express Based Main Board 3Y MBZ490
2TB M2 PCIE 3.0 X4 MVNE SSD 3Y M22TBPCIE
SATA DVD-RW x24 / x48 +/- Dual Layer Compatible 2Y ODDRW24
Antec VSK4000 USB3 3Y ENVSK4US
ANTEC EA750G Pro 80+ Gold 3Y PSUEA750
Windows 10 Home Edition 64bit OEM English OSW10H
PC Assembly + Stress Test SVCAST
System Installation & Configuration SVCOPT
I was exporting short footages taken from a timeline contains a video that was created by premiere, after a while when all worked fine  all  of sudden it stoped exporting valid files with the error mesage saying:
"File importer detected an inconsistency in the file structure of 2017.mp4. Reading and writing this file's metadata (XMP) has been disabled".
I was trying to do the same with another project located in a different address and got the same error mesage.
i can't. Render any file
kglad
what adobe app?
