Wallison1
Jun 19, 2020 2:54 PM UTC
How to fix "a low level exception occurred in: DeviceController:4"
Last night I upgraded the Premiere for the last version and this message started to happen when I tried to edit a video.
"A low level exception occurred in: DeviceController:4"
The screeshoot below shows the error
Now I can't add titles or do many things.
Tried some things like this and didn't work.
https://community.adobe.com/t5/premiere-pro/how-to-fix-quot-a-low-level-exception-occurred-in-h-264-exporter-4-quot-please/m-p/11148457#M272520
Can somebody help me?
Mitch W
Mitch WCorrect answer
Oct 7, 2020 4:40 PM UTC
The issue only occurs in 10.13.6 and happens anytime the preferences are touched. It's irratating, but otherwise harmless. Update the Mac OS to resolve.
Jun 30, 2020 9:50 PM UTC
Hi
You just have to enter the "Preferences" select Device Control and choose "Devices" None. The problem should be solved immediately.
Jul 3, 2020 12:39 AM UTC
-- Thanks, I dont know why changing this setting in Premier fixed my Media Encoder Issue where it would distort/glitch the video it was rendering but it worked.
I am using Adobie 2020 with Mac OS High Sierra 10.13.6
mich777
Jul 20, 2020 11:38 PM UTC
Thank you!  I was having this issue on Friday after updating.  Crashed all day under deadline until I finally got my cut out!  I am on a mid 2017 imac with 10.13.6
Also titles not working properly either.  I spent hours with Adobe's tech support removing the old CC apps and putting it all back together again.  This is super frustrating because I had the older versions loaded for other clients who have not updated in house.  Now I still have to figure out how to get the old versions of Adobe back.
Super frustrating.  Wish I had looked on this thread first.
I hope this fix works!
Jun 30, 2020 5:04 PM UTC
Same problem after update to 14.3 on Mac OS 10.13.6. Supper laggy playback (worse than "normal" pp lag), often just a black screen indefinetly, and this low-level exception error. Another update, another-show stopper bug.
System requirements page says "macOS v10.13 or later" for both required and reccomended. If indeed "10.14 is probably where you want to be for 14.3" then update the recomended system requirements. Or... you know, test this stuff. We all uncovered this issue within seconds of upgrading. You have a whole department that tests releases. Right?
Either way, respectfully, get it together.
Until then, luckily there is a workaround:
File - > Export Final Cut Pro XML
Open in Resolve or FCP
Jun 26, 2020 10:38 PM UTC
Wallison1,
I am so sorry for your frustration. I can see that you are not alone in getting this error. I suspect it is a bug related to your OS. Everyone on this thread is running macOS 10.13. Is it all possible to update your OS or test on another machine running macOS 10.14? I'd say 10.14 is probably where you want to be for 14.3. It is running perfectly here in my home in San Francisco on 10.14. Try it if you can. Sorry again for the issue.
FriNightCooking
Jun 26, 2020 11:11 PM UTC
I am unable to upgrade to 10.14 on my Mac.  So that isn't very helpful (for me).  The rollback version for Premiere was super helpful.  Thank you.
FriNightCooking
Jun 26, 2020 9:48 PM UTC
I'm having the same issue after upgrading.  And, consistently can repro the error...
- Switching Video Rendering and Playback to Software Only [Project Settings] did nothing.
- I do not use any type of capture card.  All my video is shot on high end cameras and imported from memory cards.
- Also, and probaby the most important, I can also trigger the error every single time by just trying to rename a seqence in the project panel.  Every time!
 PLEASE HELP!  I would love for you to fix this, but this is more than rediculous at this point, Adobe.
At other creators recommendations, I'm downloading DaVinci Resolve and exploring alternatives as I have not choice if I wish to stay in business.
Jun 26, 2020 10:13 PM UTC
I am not seeing this error until I go to open a menu. Such as Preferences>Genreal or Edit>Project Settings>.
When I first open up it is fine until I start opening menus, then I get the same error. I can duplicate the error EVERY TIME when I open Premier Pro>Preferences>General. Not sure why...
System:  Imac (Retina 5k, 27 Inch, 2017)
macOS:  High Sierra v. 10.13.6
CPU:      3.8GHz Intel Core i5
RAM:    OWC 2x16GB 2400MHZ DDR4 SO-DIMM PC4-19200
              Apple 2x8GB   2400MHZ DDR4 SO-DIMM PC4-19200
Storage: 2.12TB Fusion Drive
Adober Premiere Pro v. 14.3
Jun 25, 2020 3:06 AM UTC
try disabling preferences / playback / enable mercury transmit. That did it for me
Jun 26, 2020 6:19 AM UTC
unfortunately did not solve it for me..
brendan42069333
Jun 24, 2020 2:29 AM UTC
Samezies
I'm on an iMac
Adobe Premiere Pro 14.3.0 (build 38)
MacOS 10.13.6 High Sierra
no peripheral capture cards or anything extra in use now
all CC apps are up to date
This issue interfered with my export of a linked AE comp, through Media Encoder, defaulting to the video content that was on the timeline hours ago, before I had done a "replace with After Effects composition" and created motion graphics in AE.
Manually reimporting the AE comp and putting it on the PR timeline worked but that's a dumb extra step.
Jun 22, 2020 8:46 PM UTC
Having the same problem,
no peripheral capture cards or anything else
posting here so that I am notified when the problem gets solved
Jun 23, 2020 9:13 AM UTC
I have the same version of PP and the same OS!  I’m using a 2016 MacBook Pro.
Jun 22, 2020 11:18 AM UTC
I'm getting the same error message. My Premiere Pro automatically updated recently. It's version 14.3.0. Do you know what the problem means and how I can fix it?
Jun 26, 2020 10:32 PM UTC
I have the exact same issue. nothing helps. Exasperated.
Jun 29, 2020 10:06 AM UTC
I've updated to OS 10.15.5 and I think the problem is now resolved.
Adobe Employee
Jun 19, 2020 4:41 PM UTC
Hi Wallison1,
Sorry to hear about this. Are you experiencing this after updating to Premiere Pro v14.3? Also, please attach a screenshot of the Control Surface, Device Control, and Playback preference window in Premiere Pro.
Sumeet
Jun 20, 2020 3:43 PM UTC
Hi Sumeet-
I have no idea what happened but my error messages have stopped appearing.  Please lmk if by them disappearing I can somehow help others with this issue.
Andrea
Jun 19, 2020 3:31 PM UTC
Wallison1
Please answer the question: Do you have a capture card or something simular.
Wallison1
Wallison1Author
Jun 19, 2020 3:56 PM UTC
Just found out that is Gráficos HD Intel® 3000.
It need to be at least one of this to work fine.
Well thank you anyway.
