Premiere Pro 2020 glitch in export
  • November 8, 2019
  • 5 replies
  • 14765 views
I have been struggling with this issue for a long time and it's frustrating that I can't get the video I'm expecting. I have a 15 min video that I want to encode but I keep getting glitches every time I export. So far the glitch has been appearing at the same spot every time.
I had this same issue with shorter videos (5-8 min) every time I exported with H.264 and I was able to avoid the issue by exporting on a Quicktime Apple ProRes 422. However, now this workaround is not working and I'm getting this glitch with every format and codec I use.
The preview looks fine (no glitches). I only see the glitches on the export. I'm getting the same result when exporting directly and when exporting from the Adobe Media Encoder.
I took a look at these similar posts:
And none of those solutions are working for me. I also tried restarting the app and exporting, and restarting the computer and then exporting (this was suggested on a different post).
Computer Specs:
  • OS: macOS Catalina 10.15.1
  • Processor: 2.4 GHz 8-Core Intel Core i9
  • Memory RAM: 32 GB
  • Graphics: Radeon Pro 560X 4 GB, Intel UHD Graphics 630 1536 MB
Export Settings:
  • Time interpolation: Frame Sampling
  • Software Encoding
  • Render at maximum depth is OFF
  • Use maximum render quality is OFF
  • Bitrate encoding: VBR, 1 pass
  • Bitrate: 8 Mbps
  • Preferences -> Media:
    • Hardware accelerated decoding is OFF
  • Preferences -> Audio Hardware:
    • Default Input: No Input
I don't know what else to do. Do any of you have an idea how I can get the video to export correctly?
Hi! My solution was to export as HEVC (H.265) and then 'match source - high bitrate'. Not sure why, but this worked for me.
finally I think we're getting somewhere.  Export the original file (or just the pertinent section) as a prores422HQ file and replace it in the timeline...  HEVC is heavily compressed and that may be the source of the problem.  If you do the whole file (rather than just the clip) you should be able to unlink the clip in premiere and then relink to the prores file.
It looks like this did the trick! I exported the source file to the settings I wanted for the final video and then edited and exported that video and now I don't see any glitches. Thank you, mgrenadier!
sadly i did what was told here but it didnt work T.T
can anybody help me out?
what is the codec of the source clip?
Video Codec Type: HEVC 4:2:0
try setting your preview settings to match your intended export settings, render the section and then enable "use previews" in the export dialog
Just tried this and it didn't work... I also started seeing the glitch in the preview (only at times)
So just to be clear, your seeing this glitch at just one place every time you export?  Is this a clip that has a speed adjustment?
Tell us the settings for the source clip and your sequence settings(frame rate, codec and pixel dimensions).
glaustin
That's frustrating.
You could try importing to Media Encoder, rather than sending to it from PPr.
Did you import via media browser or direct into the project panel? You've probably tried this, but have you imported a fresh copy of the clip via media browser and replaced the clip on your current timeline?
Another thing you could try is transcoding that clip on the timeline and then exporting.
Just tried this and it didn't work... Not sure what's going on
