Premiere Pro shutdown without when I try to delete a point in a mask
- May 18, 2024
- 13 replies
- 993 views
I'm on Adobe Premiere Pro version 24.3.0. I slipped the clip in two to change the mask that will differ from the previous keyframe. I was trying to delete a point on the mask on Adobe Premiere Pro in video frame by pressing ctrl and hold and clicking on a point I wanted to delete. But every time it closed expectedly without notice. And sometimes, I see "Low Level Exception in Mask (AEVideoFilter:15)" error before Premiere Pro closes. If it worked, then the point on the mask should be deleted. I don't have any third-party plug-ins or panels installed. I use a Dell Latitude 7480 and my operating system is Windows 10 Pro 22h2. It has a Core i5-6300U CPU with speed up to 2.40 GHz, 32GB RAM HMA82GS6AFR8N-UH 1x16GB, Kingfast 512GB SSD, and Intel(R) HD Graphics 520.
