It seems like this normally works but lately when I use 'Replace With Clip > From Bin" with the new clip highlighted in the bin, it replaces it, but does not respect the In/Out points - it just places the new clip there at its start.
If you are versioning a clip, as in you had a previous Master you used in multiple spots within an edit, then received updated color, fx, etc, and wish to replace it throughout the Edit, the best practice would be to use “Clip → Replace Footage” from the Project window. This will Replace every instance of that clip in all edits, respecting the timecode.
Replace with Clip from Bin is intended to replace one clip with an entirely new clip, respecting the video in point of the selected Clip in the same bin as the sequence. If multiple clips are selected in the timeline, it will replace all of those shots with the same clip starting at the video in point of the selected clip.
Original Sequence with Source TC ShowingClip → Replace Footage (Make sure you have the right clip selected in the Active Project Panel)Select your New MasterWill maintain Relative Timecode. New Master had been exported starting at hour 0, but was the same total run time of the old version.
Let me know if this isn’t working for you in the latest version.
Well replace with clip - match frame is not *exactly* the same as shift+alt dragging the clip over the timeline instance.
(And I've seen them all behave inconsitently at times)
Replace from Source Monitor – Match Frame Method
1st selected timeline clip → syncs timeline playhead with playhead in Source Monitor Example: If the timeline playhead is 5 seconds into source clip 1, and the playhead in the Source Monitor is 20 seconds into source clip 2, then after replacement, the timeline playhead will be 20 seconds into the new clip.
Shift + Alt + Drag from Bin
Matches playhead-relative position between selected timeline clip and dragged bin item Example: If the timeline playhead is 5 seconds into source clip 1, the replacement will begin 5 seconds into source clip 2.
Which is Alt+Shift drag on top. In After Effects it's just Alt drag on top. I love it when the software is for very similar purposes and has Slightly different shortcuts.
But also it currently has a bug, like I mentioned, that causes it to not work if it has a percentage speed change. It Does work fine if the speed change is done as a time remap with keyframes though. And in after effects it just works fine all the time.
It works Mostly, if you add the new file to you bin first (or have a bin open if it's in a different prproj). Drag the file over top of the timeline clip you want to replace and hold Shift+Alt.
That does Not work if the clip has a speed change though, which is a bug. But annoyingly, I tried reporting that. And adobe employee said yea, that seems like a bug. Then proceeded to tell me to spend a bunch of time doing steps to show them exactly how it is a bug. I don't have time for that, so for now you just have to change the time to 100%, replace it, then change it back.
Thanks for responding. Yes, it is. To be clear - here's the problem I'm encountering:
I am trying to replace a clip and/or audio file on my sequence with one from the bin. They are the exact same duration and spec, but let's say, without a watermark, a new updated master, a slightly changed graphic, etc. But same file length and everything else.
Let's say I have the clip cut so that the second half of the clip is on the sequence. I would like to replace the clip with the new updated one, and not have to spend the time to find the exact In point on the new clip, drag in, etc. So that when I replace the clip, it seamlessly updates at the exact same In point of the new file.
You can do this in AE and I know i've done it in the past in premiere, when I use the "Replace with Clip > From Bin" function. But for the past few years, when I do this (yes with the exact same media length, specs, etc), it throws the new clip in there from the beginning of the file. So essentially it does not respect the In point that exists on the file in the sequence.
I'm Kevin, one of the moderators here. I'm looking into some older issues.
Are you still having trouble with this issue, or have Ann's responses been helpful to you? Please let the community know. Any other details might be helpful. See, How do I write a bug report?
I hope we can assist you if you are still having this problem. I can also move this bug report into the feature requests forum, just let me know. Sorry for the frustration.
Thanks, Kevin
....unless you are using a production, because the footage on your timeline isn't in your bin. Productions are really nice, but that is something they overlooked for sure.
So the only way to replace something on the timeline from footage in a production is to drag the footage in, so you need a way to match the in/out points.
Yeah, replace footage is basically the same as making the footage offline and relinking, correct?
I would like to avoid this becaue some of the new clips are 4k whereas the previews were 1080, etc, might be a different codec, I just don't want any weird stuff happening.
But thank you so much for your input! I think I might suggest this as a feature request.
