xX3xecutionerXx
ucrtbase.dll Issues anyone have a Fix for this. Please help Cant launch Premiere
  • December 23, 2017
  • 8 replies
  • 126520 views
Spoke with adobe support and they said not their problem its a windows Visual issue.  Anyone have a solution to this was working fine yesterday now wont get past the loading in screen.
Faulting application name: Adobe Premiere Pro.exe, version: 12.0.0.224, time stamp: 0x59d4c660
Faulting module name: ucrtbase.dll, version: 10.0.15063.674, time stamp: 0x8ac9f9d4
Exception code: 0xc0000409
Fault offset: 0x000000000007350e
Faulting process id: 0x33e8
Faulting application start time: 0x01d37c0f446fd4e0
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2018\Adobe Premiere Pro.exe
Faulting module path: C:\WINDOWS\System32\ucrtbase.dll
Report Id: 468fa311-8ad9-4e0e-a766-4544deec5491
Faulting package full name:
Faulting package-relative application ID:
Correct answer xX3xecutionerXx
We found it to be a issue with the computer I'm using the DLLS are on a protected network that when i wasn't connected to my work network premiere couldn't access it. Now as long as I'm VPNed into my work network it will work.
In my experience I have detected the problem ucrtbase.dll crash mainly in Corel all versions including the 2024 produced by the LG monitor driver, for example LM 600p 31.5 (LG FULL HD.inf) inches, it was a headache, there is nothing documented about this, I do not recommend installing the monitor drivers.
debrasteed
This a common error occurs when you try running program or game and to run them the file ucrtbase.dll is missing. There is a different solution to the error as it occurs due to different reasons. It is one of the DLL file associated with Microsoft Visual C++ and to fix ucrtbase.dll try below 3-steps:
  1. Restart Your Computer
  2. Install ucrtbase.dll to program folder
  3. Update/Rollback your driver
Same problem. VC redist reinstalled, soft reinstalled/
win10pro latest/
And same behavior with Corel 24.3.1.576.
V_F_
Again this is the correct solution:
Vanessa Ferreira (to xX3xecutionerXx) 11 months ago
Hi there!
The URCTBASE.DLL is the dynamic link library file associated with Microsoft Visual C++ redistributable package.
Please try these steps:
1. Try to repair all the Visual C++ files in control panel - program and features
2. Try to run Microsoft Visual Studio to repair all the C++ DLL files
3. Restart Machine
4. If that doesn't work then try repair all the Visual C++ files then clean install Adobe applications.
If all this doesn't help, please contact Microsoft to get the windows dll repair.
Hope this help!
Problema resolvido com a instalação do sistema, do Windows.
Melhor jeito, sem quebrar a cabeça.
Estou com mesmo problema. Nada resolvido ainda.
V_F_
Hi, still waiting for update, any step worked?
Cheers
xX3xecutionerXx
xX3xecutionerXxAuthorCorrect answer
How did you solve this problem because I think I have the same error on another software. Thanks
V_F_
Hi there!
3. Restart Machine
Hope this help!
Really good !
xX3xecutionerXx
Solutions we have already tried.
     Restarted System
     Uninstalled Premiere and preferences and Reinstalled
     Contacted Adobe support
     Photoshop guys had some of the same issues but none of the fixes translated to Premiere
xX3xecutionerXx
I will try these solutions thank you will update this thread if any of them work
