Search engine does not return results in IE for Responsive HTML5 help
  • October 12, 2017
  • 4 replies
  • 4410 views
I'm using RoboHelp 2017 to generate responsive HTML5 help. I noticed that, while the search function works for both Chrome and Firefox, it does not work when the help is opened in IE 11. I tried this from both a web server and a file server with the same results. I experimented a bit with the search settings in RoboHelp but to no avail. RoboHelp 2017 is up-to-date with patches. Has anyone else seen this issue (and found a solution)?
Correct answer Peter Grainge
I have tried that but its still the same.. using 2017.
I imported the latest .slz for the Indigo from the Robohelp website.
Returns search results in chrome instantly whilst ie11 just hangs with the search box going round and round.
OK. In that case, I think the files attached to the bug report below will fix the problem for you.
Tracker
See www.grainge.org for RoboHelp and Authoring information
@petergrainge
I'm having this issue now, too, where in IE11, the Search feature doesn't work. It's been 4 months. Has anyone heard when this bug will actually be fixed and released?
Jeff_Coatsworth
Did you try the fixes in the Tracker item?
Peter Grainge
Jeff. They will work but the files on my site are from Adobe and it will be
cleaner when Adobe issue them officially.
Help others by clicking Correct Answer if the question is answered. Found the answer elsewhere? Share it here. "Upvote" is for useful posts.
ENTRGWHAuthor
I put them here:
C:\Program Files (x86)\Adobe\Adobe RoboHelp 2017\RoboHTML\ResponsiveHelpExt\widgets\common\scripts
raylangivens
Hi again. I placed the two files in C:\Program Files (x86)\Adobe\Adobe RoboHelp 2017\RoboHTML\ResponsiveHelpExt\widgets\common\scripts and renamed the "bad" files to "old." The latest server build contains the rebuilt help. Unfortunately, the Search function is still not working in IE. Do you have any further recommendations? If not, I guess we'll need to restore the two "bad" files, remove the "good" ones from C:\Program Files (x86)\Adobe\Adobe RoboHelp 2017\RoboHTML\ResponsiveHelpExt\widgets\common\scripts and add the "good" ones to the output, because informal testing showed that that solution did work..
I can send you the help project if you want to look at it.
Jeff_Coatsworth
If you put the two new fixed files back into the "factory" location and regenerated the help and it DIDN'T work, but manually put them into the generated output and it DID work, then I'd be checking the generated output to ensure that the changed script is actually getting into what you're creating. If it's not, then you need to have a closer look at where it's getting those old files from.
ENTRGWHAuthor
The second fix also works for me. Thanks Peter. Also thanks to William van Weeldem.
Peter Grainge
In the SSL dialog import your layout again changing the name to Whatever2.
Generate with the new layout. I think you will find it works then.
@petergrainge
hi,
Sorry to jump on this. I am having exactly the same problem.
You mean import the Indigo screen layout again?
Peter Grainge
Yes, exactly that. Don't trash your old one yet so call it Indigo2 or suchlike.
@petergrainge
