dublove
질문
After 40 days of hard waiting, I can post again. I feel it will happen again.What should I do?
  • April 26, 2022
  • 2 답변들
  • 323 조회
After 40 days of hard waiting, I can post again. I feel it will happen again. Did Adobe officials notice it?
I've met it several times.
I can't click on the options in the figure below.
If I click send, I will be prompted to correct the highlighted error before sending.
I asked similar questions and found that I was not the only one who encountered such problems.
There is a way to say: delete browsing cookies. I've tried many times, but it doesn't work.
I can only wait
Later, after dozens of days, you can post again.
Very depressed
이 주제는 답변이 닫혔습니다.
2 답변
dublove
dublove작성자
I can only wait
Very depressed
Nancy OShea
Which browser do you use?
This is from Google Chrome Help
https://support.google.com/accounts/answer/32050
This is from Firefox Help
https://support.mozilla.org/en-US/kb/clear-cookies-and-site-data-firefox
Moving this to the more appropriate Using the Community forum.
-Manan
-Manan
