Could you elaborate a little more on how you used to do this and the media you are working with? I was just able to add a speed ramp on a test clip, and change this by right-clicking the clip in the timeline > Time Interpolation, and then see the changes applied for Frame Sampling,
Could you elaborate a little more on how you used to do this and the media you are working with? I was just able to add a speed ramp on a test clip, and change this by right-clicking the clip in the timeline > Time Interpolation, and then see the changes applied for Frame Sampling, Frame Blending, and Optical Flow options. Is this what you are referring to or something different?
/t5/premiere-pro-bugs/optical-flow-and-frame-blending-haven-t-worked-on-speed-ramps-for-about-7-years/idc-p/15460106#M54288Aug 14, 2025
Aug 14, 2025
I dont think it does work. Its not worked through 2 or 3 pc's and numerous Ppro versions, its very unlikely that I've had a special config that has made it not work for years. You can tell when it works when you render a time remmaped optical flow sequence and its takes a while to complete, if it does it in the same time as usual, it looks like its working, but its not.
/t5/premiere-pro-bugs/optical-flow-and-frame-blending-haven-t-worked-on-speed-ramps-for-about-7-years/idc-p/15562843#M57241Oct 25, 2025
Oct 25, 2025
I've been doing more speed ramps and I realised this as well. Its ridiculous how the supposed industry standard editor can't even get basic features right. Would be nice to be able to speed ramp then slow down to under 100 without having it look like a stop motion video.
Seems like the only "workaround is to manually cut out the constant speed parts and remove the speed keyframes, which messes up the clip so you then have to manually match it to the start of the ramps. Either that, or be forced to stick to 100% speed.
/t5/premiere-pro-bugs/optical-flow-and-frame-blending-haven-t-worked-on-speed-ramps-for-about-7-years/idc-p/15572269#M57441Oct 31, 2025
Oct 31, 2025
I'm joining this thread, as I'm having the same issue -- can adjust speed, but only in Frame Sampling. Frame Blend and Optical Flow are "options" but neither actually do what they purport. Specifically, Optical Flow is what I need. Sounds like the old solution was to enable Software Rendering in Project Settings, but Adobe eliminated that in v2025. So how do we get this to work now?
