Adjust audio speed creates tunnel sound. How to fix?
I captured some dialogue audio for a voice-over on a product video, and after editing out the white noise and background sounds in Audition, my audio clips sound pretty good. No buzz, no echo, no static. Just good clean and clear audio of the lady reading the script.
However, when putting it into the video in Premiere Pro CC 2017, I realized that she was speaking much too slow to fit the time requirements for the video, so I needed to increase the audio file speed by almost 10% to get it all to fit inside the time constraints and match the visuals. Under Speed/Duration for each audio clip, I selected "Maintain Audio Pitch" so I don't get the "chipmunk" sounding voice, but I noticed that there is now a serious "tunnel effect" to the audio. I tried to clean it up using the Essential Sound panel in Premiere, and after testing different options, chose the Dialogue option with Background Voice equalizer settings, the Background Walla Walla preset, Enhanced Speech Male and a Warm Voice reverb. It sounds much better now, but I still keep getting a slight "tunnel effect" versus the original audio clip set at normal speed.
Is there a straightforward way to clean out the tunnel sound? Any recommended settings I should try instead of what I chose?
Again, it sounds perfect at 100% speed, but even with adjustments, I still get a tunnel sound at 110% speed.
