James Joones
質問
How to Present Wall Painting Texture Designs to Clients Digitally?
  • February 23, 2026
  • 返信数 1.
  • 10 ビュー
Hi everyone,
I’ve been facing some issues while presenting wall painting texture designs digitally. When I apply texture overlays in Adobe Photoshop, the result sometimes looks flat or unrealistic. Either the lighting doesn’t blend properly, or the wall painting texture appears too artificial after adjusting blending modes.
I’ve tried using Multiply and Overlay with opacity adjustments, but I’m still struggling to keep the natural shadows and depth of the wall surface visible.
What’s the best workflow for creating realistic wall painting previews?
How do you preserve original lighting and texture depth while changing colors or finishes?
Would really appreciate your suggestions 🙂
返信数 1
February 25, 2026
Hey ​@James Joones
You may want to ask this Qs in Photoshop App.
