DoctorFalco
質問
Si è verificato un problema durante l'aggiornamento delle modifiche IA in Lightroom. Le modifiche IA future potrebbero non essere salvate e andare perse. Contattate l'assistenza clienti Adobe per risolvere il problema. CHE FACCIO??
  • March 6, 2026
  • 返信数 2.
  • 26 ビュー
All’apertura del catalogo compare questo messaggio “
Si è verificato un problema durante l'aggiornamento delle modifiche IA in Lightroom. Le modifiche IA future potrebbero non essere salvate e andare perse. Contattate l'assistenza clientiAdobe per risolvere il problema.”
NON RIESCO A RISOLVERE
    返信数 2
    Claire H.
    Hi ​@DoctorFalco, thanks for reaching out! Let’s try to get you back up and running. Here is an article that can help you with troubleshooting this issue: https://helpx.adobe.com/lightroom-classic/kb/ai-edits-storage-error.html
    A few things to try:
    • Ensure that you have admin privileges on the machine.
    • Make sure only a single instance of Lightroom Classic is accessing the current catalog in use.
    • Ensure the disk has sufficient space.
    • Restart the system and then open Lightroom Classic.
    If this does not help, please let us know, and we can continue troubleshooting. I hope this helps! ^CH
    stesso problema dopo l’aggiornamento
    Claire H.
    Hi ​@Isocento, please check out this article: https://helpx.adobe.com/lightroom-classic/kb/ai-edits-storage-error.html
    If this does not help, please let us know, and we can continue troubleshooting. Thanks! ^CH
