質問
Why does flash player 13 installation fail at 50% installation on OS X 10.9.2?
  • April 26, 2014
  • 返信数 1.
  • 373 ビュー
When I install the latest flash player 13, the installation halts at 50%. My OS X 10.9.2 is up to date. I have run the uninstaller and have deleted any flash player files in my library application support file and preferences file. I have tried installing older, archived versions and similarly, the installation process halts in the process. I would appreciate any other thoughts!
    このトピックへの返信は締め切られました。
    返信数 1
    C_F_McBlob
    Download the FULL installer:  Flash Player 13.0.0.201 (Mac OS X)
    Run it as a COCOA install:
    Double click the DMG to mount it.
    DO NOT run the installer - right click (Ctrl+click) it to "Show Package Contents".
    In Contents/Resources, double click the Adobe Flash Player.pkg file.
    The COCOA installer will open.
    Follow the steps to install.
    austinpmd作成者
    Thank you Mike M. The COCOA install process worked beautifully!
