Generated index is NOT in alphabetical order
  • February 6, 2019
  • 4 replies
  • 5296 views
Dear community,
To my surprise InDesign generates incorrect indexes. Se example below, every line starting with the surname “Dahl” should of course be kept together and be listed before any name with the same base/syllable. In this case before “Dahlbom”!
What to do?
Similar problem:
Wrong alphabetical order in index
I couldn't get @Peter Chater Kahrels script to work in InDesign 14.0.1.
Correct answer Peter Kahrel
Solo -- InDesign's index sorting is indeed pretty awful much of the time, especially with name indexes. Please go to Adobe InDesign Feedback and tell Adobe about the problem and submit a request to improve index sorting (and tell them how).
In the meantime, your name sample can be sorted correctly by setting each topic's sort order to the topic's name with the separating comma+space replaced with any character that's naturally sorted before any letter. Digits do that, so let's use the zero:
if (app.documents[0].indexes.length == 0) exit();
topics = app.documents[0].indexes[0].allTopics;
for (i = topics.length-1; i >= 0; i--) {
  topics.sortOrder = topics.name.replace (', ', '0');
P.  (Thanks for the ping, BarbBinder​)
Hi troyd71007371,
you could look into Marc Autret's IndexMatic script:
https://www.indiscripts.com/category/projects/IndexMatic
Uwe Laubender
( ACP )
Thank you, I will look at IndexMatic. The good news is that I did follow the InDesign instructions to get the index formatting working well, and it looks OK so far. I will start with a non-fiction book at 200 pages, which will have perhaps a hundred items to index, but so far so good with InDesign. As the alphabeticizing problem was in 2019, I hope that's been fixed. Rather than code it as you folks are doing, which I haven't done yet, if any index entries are out of order, and it's not too many entries, I could manually edit it by by various means, (like entering a white space where something should be and placing a single text frame over the white space, while also placing another text frame over any resulting extra index entrys that are out of order , but I hope I don't have to.)
Hi together,
in the meanwhile Peter's scripts moved to creativepro.com. So the updated script can be found at:
https://creativepro.com/files/kahrel/indesign/index_statistics.html
Uwe Laubender
( ACP )
FWIW: No idea why this thread moved to the top of the list of InDesign discussions some days ago.
Seems, this all entirely took place in February 2019.
I signed up for InDesign as a book publisher to be able to use a decent index. Looks as if the InDesign index is buggy, and hard to refine the order.  Is there another program out there that has an index that actually works well, right now, without adding code on our own?
Peter KahrelCommunity ExpertCorrect answer
Solo46Author
Thanks Peter and Barb!
Will that script edit the index data for just the active file?
Should the script file be named .JS or .JSX?
Just to see if I understand correctly. Will "name.replace (', ', '0')" change the sort order field from:
Smith, John
to
Smith0John
And one more detail. I have already used manual sorting for several topics by adding text to sort order field. It would be elegant if the script first checked if any data is present in sort order field. And if so, edits that string. If not, takes topic filed string and adds it to sort order field with comma space replaced with zero.
It seems like InDesign ignores punctuation marks when sorting. I.e. sort order field name "Smith0John" or "Smith,0John" gave the same result. So maybe the script can be edited to "name.replace (', ', ',0')".
Is it possible to add more strings to be replaced with the same replace command? Names that have no known first name in my index are instead separated with colon and then followed by title. In other words, could colon + space also be added to the replace command?
I am a bit anxious, because the index takes 30 min to generate, it contains over 7'000 lines/topics.
Solo46Author
Yes.
Doesn't matter, both work.
Well, you didn't mention that, I went by your sample and description. This changed code ignores topics that already have a sort field:
  if (topics.sortOrder == '') {
    topics.sortOrder = topics.name.replace (/[,:]\s*/, '0');
Edits -- how?
> If not, takes topic field string and adds it to sort order field with comma space replaced with zero.
That's not possible. You can have only one sort-order string.
You can now add characters. In line 5 you see [,:] and you can add characters to that list in brackets.
> I am a bit anxious, because the index takes 30 min to generate, it contains over 7,000 lines/topics.
Try it on a small sample.
P.
Thanks Peter!
Now I see that the replace function uses regex, great. I am familiar with regex, but not so good at writing JS.
> Edits -- how?
If a sort order field string already is present, then the script should prioritise sort order field string over topic field and replace the comma/colon and space with zero for sort order field string. And if sort order field string is empty the script should take the data from topic filed and replace comma/colon and space with zero and add it to sort order field (just as before).
Barb Binder
Hi Solo46,
Yes, and I remember another (different) post on this within the last few months with the same issue. Since Peter Kahrel has a script that addresses this, let's see if we can get him to swing by to help.
~Barb
