Hi everyone,
I’ve recently upgraded to Adobe Premiere Pro 2024 and encountered a frustrating issue with multi-track audio. When I try to import a video file with multiple audio tracks, only the first audio track appears on the timeline. Dragging the source file onto the timeline just doesn't bring in the other tracks, even though they are definitely there.
I’ve tried searching for a solution but haven’t found anything that works so far. Interestingly, this issue didn’t exist in Adobe Premiere Pro 2023. When I import the same file into the 2023 version, all the audio tracks come through without any problems.
I’ve attached a screenshot showing a comparison between the 2023 and 2024 versions to illustrate what I mean.
Has anyone else run into this problem or found a workaround? Any advice or suggestions would be greatly appreciated!
Thanks in advance for your help!
Attachment: Screenshot showing the difference between Adobe Premiere Pro 2023 and 2024 in handling multi-track audio.
