Problems with playback speed (Too fast) in Premiere Pro (Imported files from Nikon D4S and D810)
Community Beginner ,
Sep 23, 2015 Sep 23, 2015
Hi. I have installed Premiere Pro CC and I imported video files from my Nikon D4s and D810 cameras. During playback, the speed is too fast, and I cannot understand a word due to the speed. Why is this? Is the program mis-interpreting the fps rate? I have tried to alter the speed with shift+j or l, but the basic speed for the clips are just wrong. Anyone with tips for a frustrated new user of this program? It was not an issue with Premiere Elements or Finalcut.
TOPICS
Error or problem , Performance
135.1K
correct answers 2 Correct answers
Mentor , Sep 23, 2015 Sep 23, 2015
and look into Premiere's audio hardware settings
Community Beginner , Sep 24, 2015 Sep 24, 2015
I changed the input from the sound card to none, and that did the work!! Thanks
Sep 16, 2020 Sep 16, 2020
THANK YOU SIR OR MADAME !!! This fixed my issue!!! I was monents away from crying out of frustration because I also had to fix the green and pink video glitc. Now I can FINANY start editing my gaming videos!!! I just that hope once editing is finished, I won't have any issues with uploading. Fingers crossed 🤞🏾!!! (will post update for those who want to follow🙂)
Dec 27, 2020 Dec 27, 2020
Thank you so much for this! I was just at the banging-my-head-against-the-wall phase and this worked!!
Aug 08, 2021 Aug 08, 2021
thanks so much, this works on my problem too, cant sleep after i got this problem, constantly wondering why.. now i can sleep.. thank youu!!
Sep 27, 2022 Sep 27, 2022
Unbelievable this post is from 2015 and here we are in 2022 and it is still a bug they have not fixed!! How ridiculous is Adobe, they charge us a monthly fee but yet cant fix literally video breaking bugs smh
Nov 21, 2023 Nov 21, 2023
Super weird. (not an editor by any means)
Been working on a video with very light transitions and key effects and few nested sequences.
Rendering and saving after the render sometimes cleaned it up. I did not capture anything using premiere and did not plan on capturing any audio. I didn't think this would effect me but thought I'd give it a shot, my post renders and even pre-render playbacks are 1000x smoother. No more odd time distortion making me think a jog setting was on. Thank you!
Aug 16, 2024 Aug 16, 2024
Almost a decade later and this still works!!
Jul 28, 2016 Jul 28, 2016
I am new here and am likely missing something but the answer marked correctly has no detail on what to check in Audio Hardware settings. It's been years since I've use Premier so I am overwhelmed by the advancements since I last used it.  When I play my program to see how timing looks, it flies through it. It's just a 15 second video but it flips through it in less than 2 seconds. How can I make it playback in real time?
Mentor ,
In the audio hardware settings there are different choices for Input, Output, and such. Premiere Pro needs to be properly set in the Preferences likely for you - possibly matching audio frequency of the settings to the audio frequency of your media.
Best at for you to start a new Discussion, and state things such as Premiere Pro version, Operating System, maybe a screen shot of your Audio Hardware settings, and the media you have imported. Some that offer help will ask you identify your media with 'Media Info' ( cannot remember exact free program) , info posted in 'Tree' view (which is terminology from that program).
Doing a search should produce many threads with same issues as yours - but with yours, it seems to move very fast. Best to start a new Conversation.
Jun 01, 2020 Jun 01, 2020
That just helped me, Thank you so much. Even 5 Years Later.
Mar 13, 2021 Mar 13, 2021
I just want to say. You don't know how thankful I am for this answer. I thought I was going to lose all my progress. You saved me.
Mar 26, 2021 Mar 26, 2021
why doesn't mine work 😞
Feb 22, 2022 Feb 22, 2022
Hey! I'm in the same situation as you were! I have been driven mad. did you find a solution?
May 02, 2021 May 02, 2021
Many thank yous for the solution!!!!!
May 31, 2023 May 31, 2023
thank u mate, 3 weeks working aorund that issue, omg, thank u so much
May 05, 2017 May 05, 2017
Please help me. I've done what all you people have done but nothing is working for me. I turned the output to nothing and it fixes it but then is speeds back up again. I don't understand and it is really frustrating to me. I am almost literally pulling my hair out because this is so stressful! Somebody Please HELP!!!
Hey! I'm in thesame situation as you were! I have beendriven mad. did you find  a solution?
Jun 24, 2017 Jun 24, 2017
OSX & 50Fps Captured / Shot footage:
With your film already loaded in the Media Browser:
> Media Browser  > Right click your film >Speed/Duration > type in 50% & Enter...your film plays back at the captured 50fps with the correct audio too.
If you also need the audio in slow mo then:
> Media Browser  > Right click your film >Modify >Audio Channels >Interpret Footage >Assume this frame rate >in this box enter the desired frame rate..so a 50fps captured & then set from default 50fps (correct) to 25fps will be half speed & slooooow etc etc.
I hope this helps...works great for me.
Jul 14, 2017 Jul 14, 2017
I had the same problem just now, playback seemed to be playing frame by frame and looked laggy.
I tried your fix and it worked, all I had to do was disable and enable my sound playback on windows, nothing really to do with premiere pro?..Wierd bug
Jul 28, 2017 Jul 28, 2017
Thank you, that fixed my playback problem too, it has been days of searching! nice one!
Oct 15, 2017 Oct 15, 2017
I had the exact same problem with Adobe Premiere 2017 CC 11.1.2 (22) and I saw myself lost with a bug that renders Pemiere Pro useless.
But this thread helped me to find the Problem:
I was using my external USB Headset for sound output while editing and somehow that messed up the whole clock of Adobe Premiere.
I closed Premiere, selected my Laptop speakers as default in the Windows audio settings, restarted Premiere and the bug was gone.
Then I selected under Premiere's Preferences > Audio Hardware settings No Input and my Headset as output, it still worked but with the correct output device now.
Note that whenever I switched my Windows default audio device everything began to spook again and suddenly the sound from Premiere came out of my third sound card while the Headset was still selected in the Audio Hardware settings... After switching back and forth for 5 minutes I had it working back again. I hope Adobe is able to reproduce and find this bug.
Jan 28, 2018 Jan 28, 2018
Thank you! I've the same bug.
Nov 06, 2017 Nov 06, 2017
thanks
Adobe Employee ,
Apr 04, 2019 Apr 04, 2019
Good call,
I plugged in a (Yeti) microphone today and the Sequence began playing twice the speed.
Preferences > Audio Hardware > Default Input set to "No input"
Thanks!
Explorer ,
Jul 27, 2020 Jul 27, 2020
The issue persists in 2020...hey Adobe! Can´t you fix this for the community please?
Jan 21, 2021 Jan 21, 2021
The issue still persists in 2021. I wish Adobe would fix this sh*t.
