解決済み
Help, Wanted to make an interactive 3D with Flash cs5 and 3Ds Max
  • January 4, 2013
  • 返信数 1.
  • 1251 ビュー
Hello, I'm newbie here. I just want to make an interactive 3D with flash.
But I'm stuck with the plugins and the steps.
Some tutorials said using away3D, but the steps are too complicated, and it using flash builder too..
I have found a plugin it called Swift3D Max, but there is no tutorial for it.
Which one is better? Please Help me.
このトピックへの返信は締め切られました。
解決に役立った回答 kglad
sorry for that image,
here some detail, this is a 2D image that I made from cs5,
I want to make that a detail object (in this case i want make it a 3d object), for example that caliper, when I clicked that image (caliper) then a 3D object will show up. *3D object can rotated by user.
will this concept works?
yes, you can display a 2d object that when clicked would reveal a 3d object.  you will need to code for it to appear and to be manipulated.
返信数 1
kglad
you can use away3d with flash pro cs5 though that will probably not be the latest version of away3d.
here are swift3d tutorials:  http://www.erain.com/Support/Tutorials/
IvanHerdian作成者
Thank you, that's very very helping me.
I used it, because it said works on 3Ds Max 2012.
