Is it possible to change speed of a SELECTED PORTION of a track /in multitrack? in waveform?
Thaat's my question. There's an adorable default effect which will stretch the audio, but only to slowit down. So will it be necessary. for me to chop up my clip and extract the section I want to speed up a little bit without changing pitch (like I can do in Audacity using the "tempo" filter). And then open it in multi track to get the global stretch thing and the properties thing.... Whewww. ?? And then put that bit back into the clip I took it from??? It's like three WORDS in a talking track. If there's no alternative I'll wait and put that. track into audacity and use the "tempo" filter on my. selection. Surely a cool app like Audition willlet me do it? Or a plugin?
