Help! adobe premiere pro cc 2020 error= a low level exception occurred in: adobe player (Player:11)
Nov 14, 2019 Nov 14, 2019
TOPICS
Crash , Error or problem , Freeze or hang , Hardware or GPU , Performance
25.1K
Explorer ,
Nov 19, 2019 Nov 19, 2019
Bumping this thread because I've been having the same problem.
Votes
Adobe Employee ,
Nov 22, 2019 Nov 22, 2019
E,
Give details of your system, media, and workflow, please.
Votes
Try updating or rolling back your graphics driver directly from the video card manufacturer’s site.
Votes
Explorer ,
Nov 20, 2019 Nov 20, 2019
G'day Peru Bob,
Funny you should say - An update just came out for the NVIDIA Studio driver (441.28) but the problem persists. I had the same problem with the previous version, and I'm not convinced using an even older version would solve anything.
I have, however, rolled back Premiere to version 13.1.5, and this version of Premiere works fine.
Votes
Contributor ,
Nov 24, 2019 Nov 24, 2019
same here. Unfortunately Premiere doesn't make it easy to open v14 projects in earlier versions. so that's another nightmare.
Votes
Adobe Employee ,
Nov 27, 2019 Nov 27, 2019
Sorry about that. FCP XML is the "official" way to revert a project, for those that want to try it. If anyone needs assistance with this, let me know. I will continue to advocate for users to have an easy way to revert projects to previous versions. I'm definitely with you on that one.
Votes
Apr 22, 2020 Apr 22, 2020
forgot about this option THANK YOU!
Votes
Same thing here. No solution posted. Thanks for nothing, Adobe! (Again)
Can't roll back to previous Premiere version because then can't open current projects. Thanks for nothing, Adobe (Again)
Votes
Adobe Employee ,
Jordan,
Sorry for the frustration. Can you let me know about your system, media, and workflow, please.
Votes
Explorer ,
G'day Kevin, sorry for the late reply.
My system specs are:
AMD Ryzen 7 3700X
NVIDIA RTX 2060 SUPER
32gb RAM
I tend to work with AVCHD video.
Votes
Adobe Employee ,
How does the system react with, say, ProRes media? Can you try a test?
Votes
Adobe Employee ,
EBalma, Looks like a bug. So sorry about that. Please upvote here: https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2...
I'll be pushing for a fix ASAP for the community.
Cheers,
Votes
Dec 13, 2019 Dec 13, 2019
Any solution on that? Same issue experienced here. Just installed the Premiere Pro 2020 and the nightmare has started. How to downgrade Premiere Pro Version?
Votes
Adobe Employee ,
Jordan, looks like a bug. Please upvote this bug over on User Voice: https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2...
That would help prioritize the bug. Let me know if you need help on moving forward.
Thank You,
Votes
Adobe Employee ,
Really sorry for the issue, Farid. Can I get details around your system, media, and workflow?
Votes
Same problem here.
Votes
Adobe Employee ,
Hey Juan, sorry about this! Looks like a bug. Can you please upvote here? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2...
I will continue to push for a fix. Let me know if you need guidance on how to move forward. My apologies once more.
Votes
Apr 20, 2020 Apr 20, 2020
Hi, I just got my own system with
Model Name: MacBook Pro
  Model Identifier: MacBookPro16,1
  Processor Name: 8-Core Intel Core i9
  Processor Speed: 2.3 GHz
  Number of Processors: 1
  Total Number of Cores: 8
  L2 Cache (per Core): 256 KB
  L3 Cache: 16 MB
  Hyper-Threading Technology: Enabled
  Memory: 16 GB
  Boot ROM Version: 1037.100.362.0.0 (iBridge: 17.16.14281.0.0,0)
  Serial Number (system): C02ZJDSWMD6N
  Hardware UUID: D57D2B42-1A46-525D-9B86-2CC6D4E8EA70
  Activation Lock Status: Enabled
and now I cannot use the graphics card and my system shuts down when I open any adobe cc
Votes
Adobe Employee ,
Farid,
I heard this happens when you are shuttling fast forward. A solution to this issue (for those that have an underpowered GPU) is to choose Project Settings > General and change to Software Only for the Mercury Playback Engine.
If you have a qualified GPU, make sure it has the latest drivers installed. A clean reinstallation may be required. Then you can enable GPU acceleration.
Votes
Explorer ,
just chipping in because I'm having the same problems.
I've just confirmed that a Clean installation of my drivers does not resolve the issue.
I'm currently running an RTX 2060 SUPER, which I doubt could be considered underpowered, and I really don't wish to use Software Only mode because it runs *abysmally* on my system.
Votes
Adobe Employee ,
E,
Can you please upvote this issue? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2...
I think that would bump up the priority for a fix. The team does know about the issue and a fix is in progress, so that is the good news.
My apologies for this situation.
Votes
Contributor ,
Same issue here. According to live chat technician, it'll be fixed in early Dec update:
"By the first week of December, we will launch a new patches will be coming on which will fix the issue."
-ASHUTOSH
You can see more of us struggling with it here
https://community.adobe.com/t5/premiere-pro/premiere-pro-cc-2020-crashes-on-fast-forward/m-p/1076029...
Votes
Nov 25, 2019 Nov 25, 2019
Bumping to say I experience this as well with Premiere Pro CC 2020 on a mid 2012 Macbook Pro Retina running macOS Catalina
Votes
Adobe Employee ,
Sorry about that, Sam. Could you please upvote here? https://adobe-video.uservoice.com/forums/911233-premiere-pro/suggestions/39076387-bug-premiere-pro-2...
Votes
