解決済み
Can someone help guide me towards how to set my puppets up? Think i've over-complicated things...
  • January 4, 2023
  • 返信数 1.
  • 1619 ビュー
I'm new to CA and am trying to rig up 2 characters that I have created various sets of clothing etc for in an attempt to have everything in 1 place with the possibility of different combinations, and without too much duplication.
However, i'm not sure if i've shot myself in the foot because i'm struggling to rig them up and I can't find any examples of what i'm trying to do.
Can someone take a look and tell me what the best way to approach this is? Not sure if it would be better to choose a selection of costumes and strip out all the other artwork, then rig each one individually (although this could turn out to be incredibly time consuming).
I've attached the puppet which i started to rig up to try and get a walk animation working on (left only at the moment). If it's possible it would be great if i could keep it all in 1 thing so i don't have to create a load more puppets.
https://drive.google.com/file/d/1wxlo0soHCNtOLBuwKHYSPs2IOhC16rft/view?usp=sharing
Thanks
このトピックへの返信は締め切られました。
解決に役立った回答 Cherie2450573608fr
Hi there,
you can set up swap sets for outfits by making each outfit a layer inside the body part group (eg. torso layer would open into the different outfit artwork for torso, Right leg opens into the different outfit artwork for right leg) See Outfit setup photo.
When you create your outfit swapset remember to put in each part of the outfit (see Outfit swap setup photo)
If you do it this way you only have to rig up as normal and trigger the outfit changes.
I hope that makes sense!
cheers,
Cherie
返信数 1
Cherie2450573608fr
Hi there,
cheers,
Cherie
Thanks for your reply! I've been messing around with the art etc but I think it might be better if i create a load of separate puppets due to each lower body artwork being really difficult to get to look "ok" when walking. Putting them all into a single leg group means I have less control over how each one distorts if they're all rigged up together unfortunately.
Cherie2450573608fr
Aah, the treadmill setting. Still got weird arms but i'll have a play when i can and see what i can do because now i've got all these options i can't see myself not using them!
The waist tag will change the tilt of the body, you can move it around until it looks good. Also play around with the orientation setting, that can change the look dramatically!
Good luck!
