質問
Problem when applying small caps to CE and AH
  • January 29, 2026
  • 返信数 4.
  • 70 ビュー
I am applying a grep style small caps using the following grep code:
‭\<‬AH‭\>|\<‬CE‭\>
in some places it successfully works and in other places it only applies the small caps to the first letter. See image.
I’m not sure why it does this.
    返信数 4
    FRIdNGE
    January 29, 2026
    Thanks to remove your “moderation” on my posts!
    \<AH\>|\<CE\>
    or
    \<(AH|CE)\>
    (^/)  The Jedi
    FRIdNGE
    January 29, 2026
    \<(AH|CE)\>
    (^/)  The Jedi
    Peter Spier
    You might also try using \b in place of \<  and \>
    Mike Witherell
    Did you try applying OpenType All Small Caps ?
    This GREP Style worked for me:
    (?<=\s)(AH|CE)(?=\))
    Mike Witherell
    Summayah5FC7作成者
    Yes i applied open type all small caps.
    My method works on some but doesn’t work on others.
    I also tried your code - again works on some and not others.
