質問
Map Module - it's not Birdseye View rather than Oblique?
  • April 20, 2022
  • 返信数 4.
  • 2922 ビュー
The Map Module doesn't seem to have an option for just an oblique view of the satellite imagery. Now it looks like Bing's Birds-eye View.
I'm trying to drag images to a particular street intersection (I don't know the exact address) and the attached screenshot makes it a bit difficult.
What am I missing?
このトピックへの返信は締め切られました。
返信数 4
10047329
So in last few months salellite/hybrid map view has changed from top view to some kind of perspective.
Its bad for me for at least two reasons:
- perspective view got much older maps - at least 5 years old
- its hard to add pin to locations behind buildings
Is there a way to change satellite map view to top view?
johnrellis
A few others have reported this bug in the last couple of months.  It could be a bug in the way LR is calling Google's map service, or it could be purely a bug on Google's side. But without a reliable way to reproduce the problem on multiple configurations, Adobe won't pay much attention unless many, many people report the problem, unfortunately.
johnrellis
Camagna
Since a few days LrC Map module past a certain zoom level switches to the (horrible) Bird's Eye View, something that makes precise positioning of photos not possible anymore. Try this: put the pin where the new visualization makes you believe it's correct, then copy the coordinates and look in the real web version of Google Maps. You'll see a position very different, at least by 15/20 meters.
As my workflow requires PRECISE GPS, this is a new and really disturbing bug, the makes one of the most useful features of LrC totally a joke.
Please!! Revert to the old version!
johnrellis
[This post contains formatting and embedded images that don't appear in email. View the post in your Web browser.]
My LR 11.3.1 Map module (both Mac and Windows) shows a Google 2D satellite view for that location (around 14 Wall St, New York), while yours is showing a Google Global (3D) view.   Someone else reported similar symptoms a couple weeks ago but never followed up on whether they went away.  Since not everyone sees the Global (3D) view, I think this is a bug affecting some rather than a deliberate change affecting everyone.
Here's my LR 11.3.1 Map for 14 Wall St:
And zoomed all the way in:
johnrellis
Also, until someone can produce a step-by-step recipe that lets other reproduce the problem or until many people report it, it's unlikely it will get attention from Adobe, unfortunately.
I don't know that you're "missing" anything.  That's just the way Google Maps displays some areas as you zoom in.  My only suggestions are to zoom out a little or switch the Map Style from Satellite to Road Map.
oweniverson作成者
Maybe Bing does, but Google doesn't.
Google can, but it's not a default.
I guess yeah, standard map is the way to go. Just struck me weird not being able to see oblique satellite imagery.
Google Maps seems to default to that view for me...
oweniverson作成者
Can you not edit your posts on the Adobe forums??
Not sure about the original post, but you can definitely edit your replies.
